8550 questions
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: 8550 questions
    Posted: 20 hours 21 minutes ago at 9:43pm
Good day,
So looking at a 8550 that’s about an hour away that has been sitting for about 6-7 years due to blowing an injection line.
Seller says his son finished 10-15 acres of NH3 before replacing the line but says it still didn’t run right so he parked it in the weeds planning on repairing it but never got to it.
Seller’s pretty sure it has a hole in the piston?
If that’s the case would it be reasonable to only replace that piston and ring set?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 35 minutes ago at 10:29pm
Interesting how we go from a leaking injection line (which would leak fuel and could cause a miss-fire) to a hole in a piston ?? Two unrelated problems. It could have been a leaking number one injector line and a failed piston could be number 2 or 3 or 4 or 5 or 6 piston ?? Should have been a ton of blow-by with a failed piston. There are injector lines under the valve covers too.........
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 8 minutes ago at 10:56pm
I owned and farmed with a 8550 for many years and yes they are notorious for injection line failures. One other possibility is when they replaced the failed line the inj. pump barrel might have moved slightly, causing fuel to bypass and the engine still miss. This happened to me once, removed the one head expecting to find something and everything looked good. Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 3 minutes ago at 11:01pm
I thought that very interesting too..
Going to look at it possibly Saturday morning if all works out.
Seller drained the engine oil last spring or so to start in on the repair so I wont be able spin it over.
Is there any concerns about being a dry start?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 1 minutes ago at 11:03pm
Fill the new engine oil filters with oil before installing and start it at an idle to let the oil pressure build.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 51 minutes ago at 11:13pm
Is there a way to have a custom lines made that has thicker sides walls or bigger line with same fittings?
Never even seen one in person, only photos and videos off the internet so bear with me.
With this being told what’s a good price range to offer?
Paint is crappy (mostly brown) tires aren’t the greatest but do look like they hold air and might last awhile. Cab interior is crap, seat has a hole. Hour meter reads 3644 hours but not sure if it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 47 minutes ago at 11:17pm
Ok, didn’t know what it would do to a sitting engine.
Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 58 minutes ago at 12:06pm
Talked to the owner again today and he said it had a lot of blow by to the point of blowing oil out the breather..
Said it didn’t have any before…
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 5 minutes ago at 1:59pm
The more I read, I think this engine needs a major overhaul. If one of the diesel lines under the valve cover let loose, you could’ve had Diesel get to the bearings. You could’ve had a valve touch a piston. It sounds like the owner has told you several different things, so it could be anything and everything.
We had diesel in the oil on a 4W305. It turned out that had a bad seal on the injection pump. Every time I turned into the wind, I could smell Diesel. I managed to catch it in time and no damage was done. Sometimes it’s really good to be lucky.🍀🍀🍀🍀🍀
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 23 minutes ago at 2:41pm
Pursuing one of those sounds as bad as wanting a 45D
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 18 minutes ago at 4:46pm
Would the cylinder with the leaking injector line have caused the rings to stick from lack of fuel or poor spray pattern? Just a thought
