What model plow? |
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Topic: What model plow?Posted: 16 Nov 2011 at 9:40pm |
I just picked this plow up the other day. I am familiar with the differences in the 50,60,70, and 80 series. I have only seen 1 other plow like this.
Would it be just a mocdel 74 with a steerable tail wheel?
DougS
Posted: 16 Nov 2011 at 9:58pm |
It looks very much like a Model 70. I'm looking at the manual for it right now.
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 16 Nov 2011 at 10:26pm |
Yep, Semi mount, Steerable, Model #74. That's a nice plow and fairly rare !
Edited by Rfdeere - 16 Nov 2011 at 10:29pm |
http://www.rumelyallis.com |
Gerald J.
Posted: 17 Nov 2011 at 1:42am |
Snap coupler model 74 with truss bar. What shows in my parts catalog.
Gerald J. |
D-allis Iowa
Joined: 05 Oct 2009 Location: Akron, Iowa Points: 494 |
Posted: 17 Nov 2011 at 6:33am |
That is one plow I have never seen. I have some plows that need to be identified so now I know where to go. Do they have model # on them somewhere or how was it done.
Gerald J.
Posted: 17 Nov 2011 at 9:55am |
Of that vintage there were 5 model families. 50, 60, 70, 80, and 9000. All with the frame made up of bent bar bolted together.
50 had fixed width frame and vertical plow shanks, no trips. 60 had fixed width frame and slanted plow shanks, usually without trips but there was that option for spring trip shanks. 70 had adjustable frame width (more bolts, especially in the cross members) and slanted fixed plow shanks. There were optional spring trip shanks that would bolt in place of the fixed plow shanks. 80 had adjustable frame width and slanted spring trip shanks. 9000 were generally at least 4 bottoms and the gusset plates for the spring trip shanks were formed to bolt to the bottom of the truss bar that connects the bottoms stronger than the formed bar stock plow frame. 50 through 80 came in 2 through at least 6 bottoms, and some in flip over bidirectional plows. Those of us with a plow frame parts book can identify from a picture much of the time. Hitches for three point, pull behind, and snap coupler could often be used on several plow models. Plow bottoms were sold separately from plow frames and are not significantly useful in identifying a plow frame model, and identifying the plow frame model is very little help in identifying a bottom to find wear parts like shares and landsides. The best way to identify a plow bottom is to find a part number on frog, molboard, shin, or share, then we can go from there in the plow bottoms book to find the bottom number and to identify the parts numbers that fit, often AC offered 6 to 12 different plow shares for the same bottom of different materials and shapes. Gerald J. |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 17 Nov 2011 at 10:05am |
Yup, late model 74. We have one for the '19 and they are a very nice plow. Ours has 375 bottoms and is set out to 16". An easy puller too here moving along in the hi side of third and the 19 barely knows it is attached.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1961 |
Posted: 17 Nov 2011 at 11:04am |
I have that same plow, and agree with Butch that they are an easy puller. I pull one with a WD45 diesel or gas in 4-14. Gerald gave excellent descriptions of the variations in plow frames. The difference between the 60 and 70 is height of clearance and length. The 70 will clear more trash than the 60, by far.
TedBuiskerN.IL.
Posted: 17 Nov 2011 at 11:07am |
A model sixty plow wouldn't get 10 feet in the trash that Butch is turning over in his picture.
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2348 |
Posted: 17 Nov 2011 at 6:28pm |
I have never, ever seen one of those!!! Must be rare and very desired!! Ryan
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 17 Nov 2011 at 7:09pm |
I HAVE AN 80 SERIES BOUGHT NEW IN 1961 4-16 FOR MY D-17D HAD A AUCTION IN 1968 AN HAVE THEM ALL BACK HOME TRACTOR&PLOW MA GET A PLOW DAY NOW THAT WE HAVE A TRAILER TO HAUL IT
Missouri TOM
Joined: 02 Oct 2019 Location: Clarksville Mo. Points: 29 |
Posted: 07 Mar 2026 at 2:26pm |
Could you get this model in 5 bottoms with 3 pt hitch?
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8941 |
Posted: 8 hours 12 minutes ago at 8:21pm |
Old post but I have that same plow. It is a sweetheart!
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2326 |
Posted: 6 hours 53 minutes ago at 9:40pm |
Don't want to contradict but my thought is 84, mine is trip bottoms, does that make it an 84?
Posted: 6 hours 13 minutes ago at 10:20pm |
84 series is trip/reset bottoms, yes. The pics I see above are shear bolt design which makes it a 74 series.
Posted: 5 hours 46 minutes ago at 10:47pm |
Missouri Tom, yes, a 5 bottom fully mounted 3-point hitch 70/80 series version was available. I've only seen one, but I know they were built. So, one would think a steerable style semi-mounted 3-pt hitch would have also been offered.
Edited by DrAllis - 5 hours 44 minutes ago at 10:49pm |
