CA themostat housing
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: CA themostat housing
    Posted: 16 hours 38 minutes ago at 7:40pm
Looking for the aluminum thermostat housing for a late CA.  It's different from the cast one, perhaps the aluminum one is aftermarket?  Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 27 minutes ago at 6:51am
The aluminum thermostat housing was used on the very late production CA tractor. These were highly susceptible to corrosion and often bolts broke off when taking them apart. You can replace it with a cast iron one, it just won't be the bypass type.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 1 minutes ago at 8:17am
Thanks Paul!  That's probably what will have to happen, unless a good one can be found, will at least get it going after a little surgery was performed, Smile.
CentralMNCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CentralMNCA Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 10:47am
There is one of the aluminum T stat housing on EBAY   , in the ebay search
          this is the site # 146629216296
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 34 minutes ago at 11:44am
Thank you, I'll check that out!
