7000 fuel leak
cmalcom20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmalcom20 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 fuel leak
    Posted: 02 Mar 2026 at 9:08am
Have a maroon belly 7000. I have what looks like a fuel leak around an injector? Is it just replace the rubber gasket around it? Tried to upload pics but they’re to big
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 9:12am
99% of the time it is the valve cover gasket leaking into injector hole and back out. It is not the injector leaking. Don't be decieved...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2026 at 3:16pm
x2
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 34 minutes ago at 1:48pm
They have copper sleeves around the injectors that are swedged into the head.  If you cause one to come loose removing an injector, you have to remove the head to replace the sleeve.  Just saying that to say I would not go right into pulling an injector without ruling out everything else.
Hurst
1979 Allis Chalmers 7000
5800 Hours
