220 Questions |
Unit3
Topic: 220 QuestionsPosted: 26 Feb 2026 at 7:34pm |
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
DougG
Posted: 26 Feb 2026 at 7:38pm |
The nose is a big ole piece of cast,,,
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8928 |
Posted: 26 Feb 2026 at 9:03pm |
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5197 |
Posted: 27 Feb 2026 at 7:50am |
I've seen some 72 220's and they had the hollow front support like the 210.
Posted: 27 Feb 2026 at 9:00am |
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210. Cost savings measure. You buy MORE front end weights for an 8 bottom plow. S/n 1988 is an early 1970 model year.
Edited by DrAllis - 27 Feb 2026 at 11:57am |
CS_IN
Joined: 04 Aug 2015 Location: NC Indiana Points: 29 |
Posted: 27 Feb 2026 at 11:27am |
I will have to look at mine tonight. It is 26 from the end i believe. Its still new to me and I didn't know about this difference. It had the suitcase weight bracket on it when i got it instead of the block style weights. It does have crank driven oil pump and larger oil pan.
Edited by CS_IN - 27 Feb 2026 at 11:28am |
Kevin210
Posted: 22 hours 26 minutes ago at 10:16am |
I purchased a 220 in fall of 23 and have redoing it and getting close to having it finished and my daughter wanted it to pull with so it's her's now.
I was told it come from Iowa and had a cab on it and I don't remember the serial number off hand but supposedly it's 200th tractor from the end of production of the 220 and it also has a 210 bolster on it. |
Kevin210
Posted: 22 hours 23 minutes ago at 10:19am |
C.S.,
Did you change the front weight bracket on your 220 to slabs. |
NEVER green
Posted: 22 hours 5 minutes ago at 10:37am |
Hey!!! I want that weight bracket!!!
CS_IN
Posted: 1 hour 42 minutes ago at 7:00am |
Here is a picture of the underneath of my front axle bolster. I'm not sure which one it is but seems heavy. Below is a picture of the weight bracket. It is planned to remain as I don't have the block weights.
injpumpEd
Posted: 49 minutes ago at 7:53am |
If it looks like you could put a socket on the front crank pulley easily too turn the engine over, it's the hollow one. Still very heavy, at least 600#, but the early one is solid all the way to the crank pulley, it would be challenging to get that socket and rachet on the crank bolt. The hollow one has enough room to remove the pulley actually. I bet the solid one is over 900#. I don't think the early one has those 2 big holes either. I always assumed the hollow one was designed to help "cheapen" the price for the 210, and once they came out, it just made sense to just use the same one on the 220, and sell a rack of suitcase weights to the buyer. I don't think there's an official serial number break, but it would be interesting to know about when the 220 got the hollow one. I'd guess sometime in 71, guessing it would have taken a while to use up all the solid ones they had made already.
Mikez
Posted: 38 minutes ago at 8:04am |
Anyone have an original parts book. See what part number is. If it gives two numbers or if the original number is different then in agco parts book.
