220 Questions |
Unit3
Topic: 220 QuestionsPosted: 26 Feb 2026 at 7:34pm |
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
DougG
Posted: 26 Feb 2026 at 7:38pm |
The nose is a big ole piece of cast,,,
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8926 |
Posted: 26 Feb 2026 at 9:03pm |
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5196 |
Posted: 27 Feb 2026 at 7:50am |
I've seen some 72 220's and they had the hollow front support like the 210.
Posted: 27 Feb 2026 at 9:00am |
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210. Cost savings measure. You buy MORE front end weights for an 8 bottom plow. S/n 1988 is an early 1970 model year.
Edited by DrAllis - 27 Feb 2026 at 11:57am |
CS_IN
Joined: 04 Aug 2015 Location: NC Indiana Points: 28 |
Posted: 27 Feb 2026 at 11:27am |
I will have to look at mine tonight. It is 26 from the end i believe. Its still new to me and I didn't know about this difference. It had the suitcase weight bracket on it when i got it instead of the block style weights. It does have crank driven oil pump and larger oil pan.
Edited by CS_IN - 27 Feb 2026 at 11:28am |
Kevin210
Posted: 2 hours 9 minutes ago at 10:16am |
I purchased a 220 in fall of 23 and have redoing it and getting close to having it finished and my daughter wanted it to pull with so it's her's now.
I was told it come from Iowa and had a cab on it and I don't remember the serial number off hand but supposedly it's 200th tractor from the end of production of the 220 and it also has a 210 bolster on it. |
Kevin210
Posted: 2 hours 6 minutes ago at 10:19am |
C.S.,
Did you change the front weight bracket on your 220 to slabs. |
NEVER green
Posted: 1 hour 48 minutes ago at 10:37am |
Hey!!! I want that weight bracket!!!
