7060 seat help
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: 7060 seat help
    Posted: 27 Feb 2026 at 7:57pm
I spent most of my day today in our 7060. Grandpa bought it new so it's definitely got sentimental valve to my dad brother and I. The seat suspension needs some attention. Are we better of trying to rebuild or fab in a different seat. Would like to try and keep it original if we can. Does agco or anyone sell a seat rebuild kit with all the bushings?
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 8:43pm
Put an air ride in it .Several companies offer them . Easy installation. You won’t be disappointed. Had ours in a7045 for about 30 years now. Still use the original seat, just change out the bottom.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 9:50pm
I put new bushings in my suspension and replaced the spring/shock assembly last fall in my 7000. I also put in a replacement seat, I think it was from vevor but I am considering going back to the original. My seat wasn't bad, just the suspension. I was considering an air ride, but did some measuring and decided against it. I think the 7060 has a little more room than the 7000. I bought all my pieces separate, but I did see a kit somewhere. I have included some pictures of the process.
https://photos.app.goo.gl/q1kdkt5MJpBgr9Dg8
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 9:52pm
7000 and 7060 cabs the same size/width.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 10:08pm
Same size and width, but the back is a little different. The 7000 doesn't have the flow adjustment under the seat and continues the taper to the floor.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2026 at 6:44am
I'm not there looking at what you have, but If it was mine, I'd be ordering parts from DJS tractor parts in Stockbridge, Michigan 49285. They have an 8-brass bushing kit for $35. They have a complete new seat shock/spring assembly for $120. They have the rubber bushings at each end of your old shock/spring. I think they have almost everything you'd need other than any of the shafts, which are different. I usually just buy long grade 2 or 5 bolts from Farm Fleet and make shafts for less $$$. If you re-use your old shock/spring assembly, get a short piece of exhaust tubing from AutoZone that can be used as a spacer to shim the coil spring downwards 3/4" and no more than 1 inch. I don't remember the diameter. I just have a length I just cut out of when I do one. This will make up for the springs shorter length after 50 years and get the seat back up to a more comfortable ride height. You won't believe the difference. In any area where the brass bushing has broken and has the hole wallowed out in the steel part, I buy 1/2" steel bushing material and cut to length and weld into the bad hole. Two of those linkage areas I always make the steel bushing stock piece long enough to replace two brass bushings at once for greater strength. Always drill a small hole on top to give it a squirt of oil now and then.
Edited by DrAllis - 28 Feb 2026 at 7:10am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2026 at 7:18am
Agree with DrAllis on the repairs and upgrade of the spring. Had that done on a 170. Remarkably better than it's worn down state
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2026 at 7:51am
Rebuild your existing suspension if you want to keep it stock.  Mostly worn pins and bushings that cause problems.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2026 at 10:30am
I have rebushed four suspensions so far, my 7000 is the first time I have replaced the spring and shock. I couldn't believe the difference, and wouldn't do another one without replacing it. I was able to swap the front and rear pivot pins on the base because they wear in different spots. The pin under the seat I welded and ground back to size, and the one at the rear of the seat didn't have much wear and I was able to rotate it halfway. I have used anti-seize on the pins and bushings during assembly, but the DrAllis suggestion of a small hole to lubricate them sounds like a better idea.
Ted
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 20 minutes ago at 3:25pm
The oil hole is for when I use a length of 1/2" steel bushing stock welded in oblong suspension holes to replace two bushings. So, I'm running a steel pin against a steel bushing, so a drop of oil once in a while is good.
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 35 minutes ago at 10:10am
I rebuilt the seat on the 210 and replaced bushings and pins
but the best piece of advice I can give is to take plenty of pictures
of the seat assembly because no matter how many times you look
at before you take one apart or how many pictures you take there
always seem to be a spot you just can't remember how it goes unless
you're lucky enough to have another sitting in the barn to look at.
Just my 2 cents.
This page was generated in 0.273 seconds.
