AC running gear |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5419 |
Topic: AC running gearPosted: 25 Feb 2026 at 5:27pm |
Looking at one but I don’t know what tonnage it is. Cat no 2051584, serial number 8-4437. My guess is it’s a 8 ton?
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3646 |
Posted: 25 Feb 2026 at 6:27pm |
It’s a model AC 800 running gear. Yes 8 ton. It should have its reach pipe that goes straight through the rear frame & then is flatten & becomes its rear hitch.
Edited by AC7060IL - 25 Feb 2026 at 6:38pm |
AC720Man
Posted: 25 Feb 2026 at 11:09pm |
Would it extend enough to make a 16’ hay wagon?
AC7060IL
Posted: 26 Feb 2026 at 7:18am |
16’ hay rack? You decide. Maybe if it allows for 5 feet of overhang? Overhang could be combination that includes both front & rear frames(wheel base). Typically, the front overhang is less than rear? I’d put more emphasis on its hitch tongue length per it’s application.
Standard tongue 72”. Adjusting tongue with spring lock pin ~ 90” & could be extended. Which tongue is it? The wheel base info was listed on their OEM sales brochure. I don’t have an AC sales brochure for the 800 (era 1969-72?). I do have its predecessor 1966 OEM sales brochure FE379-668 for the AC 701 (7ton) & it states; -Track: 75”, -Wheel base: 7’-1” to 11’. -Turning Radius: 11’ (7’-1”), -Stake adjustment: 38” - 42”, -Weight: 510 lbs. Edited by AC7060IL - 26 Feb 2026 at 7:21am |
AC7060IL
Posted: 26 Feb 2026 at 7:47am |
Here’s a 2024 link where Mikez posted a 1969 AC dealer’s order sheets for running gears. On his 1st page near the bottom, it list “extra length telescoping poles”.
So it was an option. Maybe try extending the 800 & if it’s not to your liking, buy some pole pipe & fab it to your desired length?? https://www.allischalmers.com/forum/ac-wagon-or-running-gear_topic7559_page2.html |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7620 |
Posted: 26 Feb 2026 at 2:50pm |
Mine has a 16' deck on it. Used to be a forage wagon, but still has the standard length reach with the flattened end. ![]() |
AC7060IL
Posted: 26 Feb 2026 at 6:26pm |
Dseries4, Thanks for sharing about your 800 gear & hay rack. It looks great. Thinking it’s fully extended? If so could you please measure it’s wheel base?
Edited by AC7060IL - 26 Feb 2026 at 6:27pm |
DSeries4
Posted: 1 hour 45 minutes ago at 8:50pm |
Exactly 11'
DanWi
Posted: 1 hour 37 minutes ago at 8:58pm |
11 ft gear 1-2 ft overhang on the front and 3-4 ft overhang on the rear for a 16 ft rack.
