CA 3-Point Sickle Recommendations?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA 3-Point Sickle Recommendations?
    Posted: 26 Feb 2026 at 7:52pm
Considering a sickle mower for road and ditch trimming.  Prefer 6 or 7 foot.  No experience, what's a good RELIABLE recommendation, esp brand wise?  Not a situation of wanting a native or fixer upper unit at this time.
1952 CA13092
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 8:30pm
no brand, just a comment.. I have an old 1940  Allis sickle mounted on a B tractor.. Works OK... but it would be nice if  you could angle the bar and cut on slopes and hill sides... The old pitman arm type you can only tilt a few degrees from horizontal... Some models are belt drive out the the bar/ cam shaft area.. Those you can tilt quite a bit ... Something to keep in mind..
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 10:58pm
Buy an AC  82T trailer type is best bet. Easy on and of. Cut in almost any position. Use one around our pond. Works Great! Tracy
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:24am
As far as 3pt hitch mowers New Holland 451 and John Deere 350 are two of the best
DanielW View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:08am
Someone posted a similar question on another forum I follow. For what it counts, here was my response:
We use sickle mowers for all the hay at our Northern farm because it's so rocky the nimbleness of a sickle mower is handy. And because it's mainly grass we don't need conditioning like you do for legumes. We own six, and have owned many more over the years - both pitman and wobble types. For what you're describing, you probably can't go too wrong with either type. Condition would be more important. If a pitman type, make sure the jaws and knife ball aren't too worn and you set the register. If a wobble mechanism, make sure there's minimal backlash.
Although our main mower is a JD 350 wobble-type with a 9' bar, I actually think JD had the worst of all the wobble types. You really have to be on the ball with making sure you're hitting up every grease fitting on the wobble head (two of which can't be found unless you rotate the head to the exact right position and look in the right spot). They were known to wear out and break, and the parts from JD to fix are worth more than the mower.
The IH 100/1100's and the MF Dyna-Balance were the cream of the crop for smooth, balanced, durable wobble heads. The company Rowse still makes their double and single bar sickle mowers with IH heads, because they were the best for simplicity, durability, and stokes per minute. IH would be my preference, with MF and NH following shortly thereafter. But for only 25 acres you really can't go wrong with any type or any make, as long as condition is ok.
It sounds like you've used sickle mowers before so you probably already know this. But sickle mowers around here are bought and sold stupidly frequently because folks don't appreciate their nuances. It's always some horse folks who think they'll be perfect for clipping their pasture. But as soon as they realize there's a lot of skill to use and maintain a sickle mower effectively without constant headache/plugging, they give up and sell it to the next horse person (and the process repeats).
I'm a big fan of sickle mowers: they're much faster over the ground, quieter, and take less power than a bush hog. But by the time you factor in the maintenance/alignment to keep a sickle mower in-tune and needing conditions to be right (no wet crops, no previously cut crop in the path, and preferably no lodged crops), it's rare that a 7' sickle mower will actually save much time for land maintenance over a 5' bush hog. A bush hog may be slower, louder, and need more power. But you can hook it up, drop it, and go through anything. And bush hogs require almost no maintenance. Not so much with a sickle mower (at least, not if you want to be using it effectively).
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:01am
We have 2 brush hogs and a finish mower.  Immediate need is to clean up some roadside ditches and areas that are slightly hard to get to.  Long term, I'd like it to be useful for haying, but I may never get to that point (just thinking ahead).  I see online I can get a cheap brand new Chinese one for one half what most used one's are selling for :(  But I'm afraid of them.
1952 CA13092
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 25 minutes ago at 6:10pm
I have a A-C #3 rear mower on a CA if interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 13 minutes ago at 8:22pm
I'm at the charity of my brother to go pick stuff up so I'm trying to keep purchases pretty close to Jackson County Indiana.  I looked at some videos and it looked like the #3 attached easily to the curved B drawbar.  I didn't see one attached to a CA.  Since I've adapted the CA drawbar to host a 3point, I was intending that all (or most) future implements would be 3point.  I'm intending to renovate all of the implements that I have which are native to the CA (plow, cultivator, planter, disc), but it should be a fairly infrequent conversion back to pin-hitch configuration to use them (no conversion needed for the disc).  I made the conversion fairly easy, but still not completely un-annoying.  The tractor originally had more implements but they got away over the years :(
1952 CA13092
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 48 minutes ago at 8:47am
Is your CA snap or pin hitch, a number 3 mounts easily to a pin hitch CA but may have to make a mounting bracket for a snap couple,  I just bought a #3 for my snap coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 25 minutes ago at 12:10pm
It's a pin hitch but has been modified to 3 point.  I'm going to stick with new implements being 3 point for the foreseeable future.  I've got too many old implements that are in dire shape to work on.  Until I get those working, I'm going to be hesitant to take on older implements.  That was kind of the point of creating the custom (more robust than the cross manufacturing kludge contraption) 3 point.
1952 CA13092
This page was generated in 0.480 seconds.
