180/185 Pre-Cleaner Question ? |
tjs45
Topic: 180/185 Pre-Cleaner Question ?Posted: 4 hours 43 minutes ago at 4:32pm |
I have a 180 I'm restoring and it has the large hole in the hood where the pre-cleaner would have went with no bolt holes, and I have a later serial #12500 180 parts tractor that had a pre-cleaner mounted on the hood.
My old Microfiche shows the 180 without a pre-cleaner on the hood, and the 185 had the hood mounted one? I'm guessing that later serial number 180's had the pre-cleaner mounted to the hood, but does anyone know how the earlier ones without the mounting holes in the hood were setup? Did they have a small pre-cleaner behind the grill mounted right to the air filter housing? Thanks for any insight!
Posted: 4 hours 15 minutes ago at 5:00pm |
Without trying to connect all the dots from the summer of 1967 at the release of the One-Eighty, to the very last 185 at some time in 1981, I think it goes like this: the pre-cleaner extension above the hood was an option, not standard equipment, at least on the early One-Eighty's. It may have become standard equipment on the 185's, or it still may have been an option. On a gas One-Eighty, it would have been an option for sure. Any of those models that didn't have the pre-cleaner above the hood, didn't have anything behind the grille screen. Just a short stack on the air cleaner filter body. Nothing else.
ranger43
Joined: 09 Jun 2019 Location: Huntingburg Points: 170 |
Posted: 1 hour 21 minutes ago at 7:54pm |
Agree with Dr. Allis. I actually believe it was an option all of the way through the 100 series. I had a 175 diesel with and one without. The one without had a "factory" cover over the hole on the hood. Under the hood it was the same filter housing, filter, etc. just nothering connected to the T coming off the filter housing.
