fiat allis fl10
romain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote romain Quote  Post ReplyReply Direct Link To This Post Topic: fiat allis fl10
    Posted: 16 Feb 2026 at 5:22pm
salut les gars moi c'est romain j'ai un fiat allis fl10
Je voudrais savoir si l'un de vous est caler sur ce modèle et ou je peux trouver des pièces et des joints svp merci
Eric B View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 1:07pm
Welcome to the forum!
I'm no expert on the FL10 but I used to own an FL9. Parts are not easy to find but parts like seals and bearings you can research by inner and outer diameter size and with old parts removed you are likely to find letters and numbers on there. Once you have some numbers you can always type them into 'search' and get cross references. Being that the FL10 was likely made in Italy (my FL9 was) you may have some success with a search there, even for used parts. In time, you may get some FL 10 expert on this thread that will come up with the information you're looking for.
Cheers
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 3:32pm
We've got a plain FA 10 dozer.  The parts book has a table in the back which translates the Fiat bearing part numbers into standard bearing dimensions.
Following discussions on here the parts situation seems a lot better in Australia than in USA.  Which means that they are available in Italy if you can make a connection there
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 5:19am
Bonjour d’Écosse,
Je parle francais un petit peu.
Si vous cherche sur l’internet, vous devriez pouvoir trouver des concessionnaires de pièces en Italie tels que Tecno Ricambi qui pourraient avoir les pièces dont vous avez besoin - https://www.tecnoricambi.net/en/brands/fiat-allis
Vous devriez également pouvoir trouver des pièces de rechange comme des joints et des filtres auprès de fournisseurs tiers plutôt que des pièces d'origine Fiat-Allis OEM (qui seront probablement très difficiles à trouver de nos jours)
Il y a quelques informations sur ce forum - https://www.allischalmers.com/forum/fiat-allis-fl10_topic194832.html
Hello from Scotland,
I speak a little French.
If you search online, you should be able to find parts dealers in Italy such as Tecno Ricambi who might have the parts you need - https://www.tecnoricambi.net/en/brands/fiat-allis.
You should also be able to find spare parts like gaskets and filters from third-party suppliers rather than original Fiat-Allis OEM parts (which will probably be v. difficult to find nowadays).
There is some information on this forum - https://www.allischalmers.com/forum/fiat-allis-fl10_topic194832.html
This page was generated in 0.163 seconds.
