480 70R 28 tires
Joninmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joninmo Quote  Post ReplyReply Direct Link To This Post Topic: 480 70R 28 tires
    Posted: 7 hours 27 minutes ago at 3:17pm
Anyone have these on a tractor? Wondering how they compare to a 16.9 or 18.4. Was wanting to put on 16 inch rims. Thank you in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 54 minutes ago at 3:50pm
480 mm is 18.9 inches.   Have to research the 70R (radial) for height. Your tire man can tell you.
Wes(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 9:13pm
70 is the aspect ratio.  So, thats 70% of the width in mm. 480x70%= 336mm
divided by 25.4mm = 13.2" from rim to tread  "R" means radial
Edited by Wes(Va) - 1 hour 30 minutes ago at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 14 minutes ago at 9:30pm
What I find is 56 inches tall about the same as a 16.9 x 28.
This page was generated in 0.180 seconds.
