Power Steering issue
jpi72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Topic: Power Steering issue
    Posted: 2 hours 40 minutes ago at 3:15pm
I have what I believe to be a 610 AC forklift.  It has a D15 Series 2 engine in it (160 cu. in.).  I am having trouble with the power steering not responding when I first start it up.  The steering wheel is very hard to turn, and the steering wheels don't respond much.  After warming up for a while and pulling on the steering wheel it seems to just start working.  It will work fine until I shut it off.  When I restart it, it may bother again, or it may work right immediately.
The forklift works up and down good right away after starting.  I think the pump is working.
Is air getting into the system somehow?  Not sure where to start.  Any ideas?
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 8 minutes ago at 3:47pm
The power steering pump (if it is a stand-alone pump) is losing prime. Time to reseal/overhaul/teardown. I'm not familiar with the chassis, but if the lift system always works, the power steering must be a pump of its own. Or, it is a tandem type pump with PS on one end and Lift on the other. Anyway, it is PUMP issues. Nothing else.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 minutes ago at 5:44pm
I don't mean to hijack, but what if a guy is having the opposite issue? Steering works but it turns very freely and takes a lot more turning of the wheel to get the steering to respond. Steering orbital needing rebuilt you think?
This page was generated in 0.328 seconds.
