Two-Ten pto
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: Two-Ten pto
    Posted: 06 Feb 2026 at 3:00pm
my pto brake doesnt seem to work, is it a simple fix?
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 6:34am
The PTO clutch and brake are hydraulically applied. So, I guess you somehow need to "tee" in two 500 psi gauges into the steel lines going to the clutch/brake area on the lift arm housing. Maybe using a jumper hose looped around in a circle to get connected ?? With the engine running the pressure "engaged" should match the pressure when "off" in the brake zone. If pressures are equal, I'd say you have internal issues and the lift arm housing would have to come off to repair. I've never seen one that has failed. Remember, the PTO lever has THREE positions. Fully up is ON. Fully down is BRAKE. In the middle is COAST. The coast position ain't the brake position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 10:33am
It will run in coast with nothing attatched. Easy enough to knock out of "on" with your right leg when bush hogging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 2:58pm
yes i have pto  postion lever all the way down, still turns
Cowboy UP
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 9:09am
I've heard the pto valve in the 210 and 220 are likely culprits is what I've been told by others, I need to investigate ours as well, as it seems to slip under load, even though we don't really use the PTO on it.  Tried it on the grain vac years back and it slipped under when it got a good load on it.  Asked a few about it and they said the valve likely needed to be looked at and cleaned up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 9:28am
BUT, even to do that, one should pressure test the clutch and brake circuits BEFORE and AFTER you work on the valve. There may well be pressure test ports on the valve, but it's inside the console and I myself have never worked on one (yet).
This page was generated in 0.301 seconds.
