Charging 8V battery |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1566 |
Topic: Charging 8V batteryPosted: 1 hour 16 minutes ago at 4:05pm |
My friend dropped off an 8V battery out of a 1946 Ford that someone had installed. What is best way to try to charge this? I have several chargers but nothing 6V. I think the battery is no good. I will check voltage of it first and go from there. Thx.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5136 |
Posted: 1 hour 8 minutes ago at 4:13pm |
You should be able to charge it with a 12-volt charger on the lowest setting, without hurting anything.
Several battery chargers had a single setting for "12-volt low - 6-volt fast charge". Edited by WF owner - 1 hour 6 minutes ago at 4:15pm |
Joined: 11 Sep 2009 Location: illinois Points: 89823 |
Posted: 1 hour 2 minutes ago at 4:19pm |
and if you have a volt meter, connect it across the terminals and monitor as the battery is being charged with the 12v charger..
Ed (Ont)
Posted: 20 minutes ago at 5:01pm |
Thanks guys!
