Paint Hardener Question |
Oldwrench
Joined: 12 Jan 2020 Location: Northeast Points: 157 |
Topic: Paint Hardener QuestionPosted: 15 May 2025 at 8:33am |
I am not an experienced painter by any means. My general competence level is that of painting old farm equipment with a brush using whatever enamel I could find. However, I want to start to learn how to paint for real, and am planning to put some time into cleaning and repainting our D17IV as a summer project. Obviously not to a show quality, but to a decent level. I plan to use acrylic enamel. Over the winter I've read up on painting and even have a few basic books. The isocyanates thing in a hardener makes me worry. I know that for the two stage urethanes and such, full body protection with supplied air with good exhaust is necessary. However, for regular enamel, painted outside or with good ventilation, it seems a good respirator mask with the proper carbon filter material, plus the normal gloves, is sufficient. However, I have read conflicting opinions on using a hardener. It is recommended for improved gloss and durability. However, some say that even using a few ounces changes everything, while others say a good quality respirator mask is sufficient for the small amount of hardener present in the enamel. I prefer not to ruin my lungs for the sake of a paint job. But a full air-supplied suit seems like overkill. However, if that is really what is needed, then I will either re-think starting my new career in painting old tractors, or give the work to a professional - or leave the hardener out and just use regular enamel. I know this is probably equivalent to an oil-thread, but there is so much collective wisdom here, I trust the opinions. So in reality, how dangerous is it to add a hardener?
Joined: 11 Sep 2009 Location: illinois Points: 89714 |
Posted: 15 May 2025 at 9:31am |
i paint outside.. use a gravity feed gun that has less overspray... and stand UPWIND of where the breeze is blowing.... just a half mask carbon filter.
Codger
Posted: 15 May 2025 at 9:52am |
I painted my first automobile in 1973. Have owned four, (yes, four) auto body shops through the years and now retired but still spray a bit of paint. Seldom do I use the bottom of the line stuff the farm stores market, but they have their purpose. For your stated purpose a good "Pesticide" rated mask with activated charcoal cannisters is good. You don't need to be concerned with polyisocyanate poisoning with the limited exposure you'll face.
You can probably tell I'm not the "doom & gloom" painter at all. I have a downdraft paint spray room with heated make up air, etc. to satisfy the insurance requirements of a repair shop operation, but don't even bother with anything but the lights and exhaust fan to rid the the airborne overspray. Clean clothes and a fresh blow off with an air gun just before starting to spray is about the only precautions I take. I don't even use rubber gloves because I am still a man. The key to a good job is preparation with the materials selected, cleanliness, and technique. All require practice; at times, a lot of practice. What comes natural to some doesn't to others. It's been over 30 years since I've used acrylic enamel with "hardener" dumped in. Used to spray a lot of DuPont "Centari" enamel with 793S hardener reduced with 3602 acrylic lacquer thinner, allowed to set after spraying a couple of hours, and shove the vehicle out the door. You won't read that in any text but experienced painters from the era when those products were popular, (still available but not widely used due to VOC content) will tell you that was the ticket for getting a job out the door quickly. I cite DuPont, but any acrylic enamel, and fast activator/hardener would work. An activator, or hardener in acrylic enamel with outlast in shine the same paint minus this ingredient. Most will tell you the paint with flow, or level better with the additive but that depends upon technique, (IMO). It will also cure much faster. I never intermixed generic products in any manufacturer's paint products as couldn't afford the comebacks from "experimental" paint failures. Spray guns; there are a plethora of them out there. I have spray guns on the high end, and the low end. Find something that is comfortable in the hand, and sprays a 12" - 14" fan pattern at 12" from the surface evenly, and fully, with about 40 psi at the gun with the trigger pulled back. Set your gun to comfort level for speed traveled while spraying and use a 50% overlap in your application technique. These are basic guidance practices as everyone is different. Remember this when setting your spray gun: Set the fan , fill the fan. What that means is spray some paint against a piece of masking paper and set the fan spray pattern for the desired result. Then adjust fluid flow to fill that pattern. Pull the trigger back, and release, evaluate what you just sprayed. When wet, evenly filled, and not running down the paper, start with movement to ensure even coverage and no blotch. Takes practice, practice, and then a bit more practice to get comfortable. Even application is the key to a good looking finished product. Has to spray wet enough to flow and level, but not so wet it runs from the surface. Horizontal surfaces don't run right? Lay paint on really thick and it fails and/or dies back in gloss from solvent entrapment. Same application thickness no matter where you apply. 2.5, to 3.0 mils is about perfect. Acrylic enamel is very subject to hazing from humidity as it dries so try to paint when the humidity is relatively low. Good airflow over the vehicle helps but painting when it's raining or 90% humidity can have detrimental effects. Enamels are also subject to "fish eye" from the surface not being very clean and free of oils/grease before spraying paint. Clean, lint free wiping cloths and fast evaporating solvent preclude this.
That's All Folks!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5128 |
Posted: 15 May 2025 at 6:23pm |
I am strictly an amateur painter.
When I do paint, I use AGCO (Valspar) acrylic enamel paint with Valspar Renew hardener (I get the paint from a local AGCO dealer and the hardener from a John Deere dealer). The AGCO paint is reasonably priced, sprays well, shines nice and doesn't fade. I do most of my painting in the winter and I have a small exhaust fan that I put in a window (it has to be small so, I don't lose much temperature). I use a 3M full face respirator that has replaceable cartridges. I have had no problems.
Straanger
Posted: 16 May 2025 at 11:36am |
Think about the last few projects you have brought home and re-evaluate the sentence “I have had no problems “.
Sorry, I couldn’t resist. |
Comsizijo
Posted: Yesterday at 11:04am |
I just mix the hardener only if the label on the paint calls for it. Too much makes the paint brittle. Good prep, clean metal, and the right reducer matter more than extra hardener.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4033 |
Posted: Yesterday at 11:10am |
being a smart as but i dought we will all dei painting one or two tractors , not like painting 40 hours a week , i use a resporator with a carbon filter for the few hours i paint each year
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5366 |
Posted: 14 hours 10 minutes ago at 9:27pm |
The enamel PPG paint I use is a 8:1:1 mix. 8 parts paint, 1 part reducer, 1 part hardener. I also use a cartridge half mask. HPLV cheap gun from Harbor freight, does a nice job IMO. I use all my tractors on the farm but I do like them looking nice while hard at work. I tried a friend of mine full suit with ventilation system. It was cumbersome and I did not like it. I know it was better for my health but I also could not see well through the mask. I only paint a tractor or parts every few years whenever I drag a new toy home. It’s been 2 years since I did my D17, my D14 is just about ready to slip in the paint bay. Sheet metal is just about ready to go.
Edited by AC720Man - 14 hours 4 minutes ago at 9:33pm |
Posted: 1 hour 8 minutes ago at 10:29am |
agree.... but i dont just use PPG paint.. you can get the Valspar or other a Local Farm Store, etc and it will be OK to mix with HARDENER... Hardener is not just for Automotive quality paint.. I will work OK with any "farm store" enamel.
