D 14 carrier bearing |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1148 |
Topic: D 14 carrier bearingPosted: 3 hours 31 minutes ago at 4:29pm |
I'm changing the brakes on the left side now. And I noticed the bearing's race had a score mark all the way around. The steel ring shims on this side totals 0.038. The other side was 0.022. I guess that's what was needed for pinion, ring gear backlash. But does the scoring on the race show its too tight. Edited by Tim NH - 3 hours 29 minutes ago at 4:31pm |
Posted: 1 hour 49 minutes ago at 6:11pm |
No. It ran fine before. If it was too tight, it would have failed by now. Don't change a thing.
Joined: 11 Sep 2009 Location: illinois Points: 89653 |
Posted: 1 hour 28 minutes ago at 6:32pm |
what your seeing is minor damage from DIRT an CRUD in the oil that gets MASHED into the races... Roller bearings probably look the same... as Dr said, thats normal.
Tim NH
Posted: 17 minutes ago at 7:43pm |
Thank you Dr Allis and Steve for your reply's. I was completely relieved. I did notice that same color some what on the cage of the the bearing in that same area. Doing this brake job has been a can of worms.
