D 14 carrier bearing |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1147 |
Topic: D 14 carrier bearingPosted: 3 hours 4 minutes ago at 4:29pm |
I'm changing the brakes on the left side now. And I noticed the bearing's race had a score mark all the way around. The steel ring shims on this side totals 0.038. The other side was 0.022. I guess that's what was needed for pinion, ring gear backlash. But does the scoring on the race show its too tight. Edited by Tim NH - 3 hours 2 minutes ago at 4:31pm |
Posted: 1 hour 22 minutes ago at 6:11pm |
No. It ran fine before. If it was too tight, it would have failed by now. Don't change a thing.
Joined: 11 Sep 2009 Location: illinois Points: 89653 |
Posted: 1 hour 1 minutes ago at 6:32pm |
what your seeing is minor damage from DIRT an CRUD in the oil that gets MASHED into the races... Roller bearings probably look the same... as Dr said, thats normal.
