Grader DD-2408
Steve22134y View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve22134y Quote  Post ReplyReply Direct Link To This Post Topic: Grader DD-2408
    Posted: 5 hours 2 minutes ago at 8:42pm
I recently acquired an Allis Chalmers grader. It has a diesel engine. It has sat for a while. Diesel tank was empty. I have diesel to the injector pump, but can’t seem to get the pump primed. I have the lines cracked open to bleed but no luck yet. Cranked on it for a while. Any tricks? Maybe pump needs rebuilt?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 20 minutes ago at 12:24am
The shaft in the pump is most likely sheared off,those pumps would stick while sitting and then when the motor was turned over it shear the drive off.Unfortunately the parts are extremely hard to find
This page was generated in 0.104 seconds.
