Allis-B 1938
RayJay420 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RayJay420 Quote  Post ReplyReply Direct Link To This Post Topic: Allis-B 1938
    Posted: 7 hours 23 minutes ago at 2:34pm
I think 1937 no generator,12 volts, Maginto no spark yet
Tran. Oil in cyd.
Any thought
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 55 minutes ago at 5:02pm
Is it for sale or ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote RayJay420 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 35 minutes ago at 5:22pm
Not for sale, just wanted to know about lifts,ram under seat plus bar behind seat.
Also how to test Maginto.
Newbe to tractor workings
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 55 minutes ago at 6:02pm
there should be two levers below your  right butt cheek... The RIGID one attached to the differential case will engage the PTO and the hydraulic pump.( lift UP to engage).. Once the PTO is spinning, then the other lever ( sometimes attached to the bottom of the seat frame), will stroke the hydraullic valve and send oil to the cylinder, or open a port and let it bleed back to sump..
If tractor has been setting along time, the POINT inside the mag might be corroded and need cleaned.... also possible that the condenser is bad inside the mag... depending on what mag you have, you can screw up the timing of the mag gears by pulling the cover off.... you need a little more direction to remove, repair, reinstall and time the mag.
Edited by steve(ill) - 3 hours 43 minutes ago at 6:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 49 minutes ago at 6:08pm
this little girl gives a good presentation on how to inspect and repair a mag.. Look at the 19 minute mark to see the gear timing INSIDE the mag.... You might be able to remove the plastic cap and clean the point while on the tractor... if you pay attention to those two gears.... probably dont need to do anything to the IMPULSE and spring on the front end right now... get some spark first... see if the coil is BLACK ( old original) or red ( newer version)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 42 minutes ago at 6:15pm
serial number is by the shift lever... give that and we can tell you the year..  Probably not a 1937.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RayJay420 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 41 minutes ago at 7:16pm
Thanks for great info!
I need some locals to help me.
Ser # I see the B the next two # ? Then284
I will the #s right someday.
I want # off motor too
. Thanks again
Are the lift parts worth anything?.
Should I leave ram on?
