Painting a trailer |
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 157 |
Topic: Painting a trailerPosted: 08 Nov 2025 at 10:24am |
I have an old trailer that needs a fresh coat of paint. It has numerous rust areas. Rust areas are not very heavy just enough to know the paint is gone. The trailer is yellow and I would like to repaint it black. Should I prime just rust areas or apply primer to the entire trailer? I will wire brush the rust areas. Other than pressure washing what should I do to the areas that still have paint?
Thanks Avery |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35030 |
Posted: 08 Nov 2025 at 11:03am |
Will have to clear any loose paint, and scuff the surface of the rest or will not stick for long..
Joined: 11 Sep 2009 Location: illinois Points: 89493 |
Posted: 08 Nov 2025 at 12:54pm |
use a palm sander with 120 grit paper to scuff everything up.(after wire brushing the rusts)... I like the Rustoleum Red Oxide Primer for rusted spots... Also a good primer for the old paint areas.. You dont have to put a thick coat on, just enough to cover and let it BOND to the old paint.. Let it dry for 24 hours, then any type of enamel paint for a top coat.
Edited by steve(ill) - 08 Nov 2025 at 12:54pm |
AveryD12
Posted: 08 Nov 2025 at 9:41pm |
Thanks. Had not thought about a palm sander but had considered an angle grinder with a wire wheel on the painted area. A palm sander would probably be safer as that wire wheel will kick back sometimes. Just wasn’t sure if sanding/brushing was necessary. I like the rust-o-leum red oxide primer for rusty metal just wasn’t sure if it would be good to use on the areas that still had paint or if I needed to use something else. Thanks again for the help.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1219 |
Posted: 08 Nov 2025 at 10:35pm |
They have angle grinder sanding discs.
They leave a very nice bare finish, very handy cleaning up stick weld splatter and rust pits. |
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5108 |
Posted: 09 Nov 2025 at 6:10am |
I first use a needle scaler to remove anything loose, then sand it. I blow it off with compressed air and wipe it down with Preps-all. Then I use Rust Reformer | Rust-Oleum over any spots with visible rust. Let the Rust Reformer (or Rust-Converter) dry, prime with a primer that is compatible with the paint I am going to use. Lightly sand again, blow it off, another wipe down with Preps-all and paint. I lightly sand, blow and wipe between paint coats.
AveryD12
Posted: 09 Nov 2025 at 6:57am |
Thanks everyone for the great tips!
AveryD12
Posted: 07 Jan 2026 at 5:59pm |
![]() Hope the picture loads. Thought you might want to see the finished paint job. Not great but a lot better. Thanks for all the advice Avery |
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8469 |
Posted: 07 Jan 2026 at 6:21pm |
looking good... worth the time it took to do the job.
55allis
Posted: 07 Jan 2026 at 9:17pm |
Looks like a new one!!
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24924 |
Posted: Yesterday at 6:11am |
yessh... I was thinking 4by8 'trailer', WOW that thing is HUGE !!! and PRETTY !! Can it can a 'B' though !??
AveryD12
Posted: Yesterday at 7:45am |
Thanks everyone. I have owned it about 12 years. Bought it with the intention of doing “this”. Just now getting around to it. I might tend to procrastinate a little 😂. New paint, new lights, new reflective tape & new safety chains. Deck is only a few years old. Should be good for several more years now.
WF owner
Posted: 17 hours 24 minutes ago at 3:22pm |
One thing I have learned over the years is the 3M Diamond Grade tape is the only thing I have any luck lasting over a couple years. It is pricey, but in my opinion, it's well worth it.
