Snap coupler requirements
Matt0926 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt0926 Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler requirements
    Posted: 02 Jan 2026 at 6:36pm
I’m looking into putting a snap coupler on my b, however none of my allis tractors have had one so I don’t know what to purchase to be able to have the full system any pictures or help would be much appreciated, thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 6:52pm
what does that gain you ? Regular 3 point or hitch would be more common.... do you have the implements for it ?
Edited by steve(ill) - 02 Jan 2026 at 7:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt0926 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 7:53pm
Edited by Matt0926 - 02 Jan 2026 at 7:59pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 8:12pm
Think it would be easier( and probably safer) to trade up to a ca
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 6:13am
They made one for the B, but it's very rare and would be very expensive.  OK Tractor sells a 3 point kit for a B.  Expensive, but modern.  Not sure what your goal is, but you can't hang much off the back of a B anyway, so if you want a lift, I'd suggest moving up to a CA or WD/WD45.
AaronSEIA
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 9:48am
A snap coupler B would be oh so very cool! Cool And properly weighted the narrow wheelbase would be about ideal for plowing small lots methinks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt0926 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 7:53pm
That was my thought
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 8:09am
Since snap coupler parts for the Model B are practically unobtainable, the standard one bottom plow setup is probably the best option. A two-way plow would be especially handy and those can still be found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 5:40am
Be easier and cheaper to just buy the 1 or 2 way mounted plow they made for the B.
AaronSEIA
This page was generated in 0.621 seconds.
