Home heat oil stove
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: Home heat oil stove
    Posted: 17 hours 17 minutes ago at 11:19am
I've got an old Monogram oil stove that was used for home heating. Has a reastat run fan built in to oil flow control. Just lately has started to lose fan speed after an hour or so running. Visual inspection of reastat and electronic spray cleaning hasn't changed anything. Fan spins freely and have oiled it to boot. Is it the fan motor dieing or reastat failing? Have owned it 50 yrs. I suppose a voltage check out of reastat is what i need as it just starts slowing down. Shut it down for a while and it works again. Don't know what to do. Used to heat my shop. Any ideas? TIA that fan has alot of hours on it. How would a pro diagnose it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 30 minutes ago at 1:06pm
i would bypass the thermostat.. Run power straight to the fan and let it run wide open all day long... Would be a good test to determine if the motor has a problem... Old windings could be breaking down when hot, or bearing could be  expanding with heat and causing a little drag...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 58 minutes ago at 1:38pm
Yeah i wonder if it has brushes. Need to try your suggestion first before tearing into. I don't understand why stuff don't last forever......
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 24 minutes ago at 6:12pm
Are you using ‘electric motor oil’?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 4 minutes ago at 6:32pm
It is "3 in 1" oil. Isn't that correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 32 minutes ago at 7:04pm
3 IN 1 is good for door hinges, bicycle chains, etc. There is specialized oil, for electric motor bearings. I do believe the makers of 3 IN 1 do market a specialized grade of lubricant oil, with ‘For Electric Motors’ printed in bold lettering on the front of their little cans.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 26 minutes ago at 9:10pm
Go to a Hobby Shop and get some of the stuff they use on model RC airplanes and car motors. It made me a believer on a grandfathers clock works that refused to run on 3 in 1 oil. More reastats that came to me ailing needed to be cleaned or replaced, more than oiled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 31 minutes ago at 11:05pm
I washed down the reastat coil with electrical contact cleaner. Didn't oil it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 minutes ago at 4:13am
Main issue is time on rheostats. Moisture and/or damp air to being close to the higher heat of a machine or furnace having ill effects on moisture delivers really foul corrosion or in air mineral buildup. At the nuke on a number of the oldest systems we actually had instructions to periodically ‘Wipe’ the system rheostats to burnish the buildup of corrosion or mineral deposits off.
This page was generated in 0.193 seconds.
