57 international s-100
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: 57 international s-100
    Posted: 18 Dec 2025 at 8:28pm
A few months ago I picked up an old truck with the plan of fixing it up with my brothers and giving it to dad for his 80th birthday. His first truck was the same model but a year older. The body is fairly decent and it runs and drives but has some issues. The biggest one being it has a cracked block. Right behind the starter. Not a big leak it just sweats a bit, no drips. I plan on pulling the engine and transmission and looking them over before deciding what to do with them. I would like to keep it more or less original but wondering if I should braze the cracked or just use some sort of epoxy? Anyway if the engine turned out to be healthy I would also like to put a fuel injection system on it. Anyone have some thoughts about that? Planning to remove the body and clean up the frame and then figure out what to do with the brakes. I am pretty sure it is still a single line braking system so not a great design by today's standards. Just want to make it a decent enough truck for him to cruise around in whenever he feels like it. Get the mechanicals working good and let him do whatever he wants with the body. I am pretty sure that he would prefer it to be left just the way it is with 70 years of use for everyone one to see.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2025 at 7:29am
I'm wondering if the crack could be JB Welded. I have heard of engines being fixed with that stuff before.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2025 at 8:01am
I have an IH R-150 here that I'm working on. Motor was seized. Head had a 9" crack. We sent it to a machine shop in the city and had it properly repaired. Looks great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2025 at 8:57am
Due to heat expansion and contraction JB Weld will be extremely short term, Having a Machine Shop that repairs broken castings is only good choice but expensive.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2025 at 11:08am
probley just arc weld it with some 90% nickel like,   MG250 or radnor99  it will cost about 30.00$ per rod    but could get away with minimal heat short welds lots and lots of peening as soon as you break an arc
This page was generated in 0.271 seconds.
