Milton engine starter switch
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Milton engine starter switch
    Posted: 14 Dec 2025 at 12:03pm
Came with a old Penske timing light I bought. Can't get it to work. Red clip goes to pos battery post. Black clip,neg post. Blue clips to white wire on D 15 solenoid? This sound correct? Switch is probably at least 50 years old. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2025 at 6:52pm
Depends on how the switch is made.. Are the 3 wires all smaller gauge like 16 or 14 gauge ? Normally a  "SWITCH" just needs a hot wire ( red) and a signal wire to the solenoid... Push the button and you put 12v to the solenoid small terminal and it pulls in the coil and the two BIG LUGS are connected... This assumes the solenoid or the second SMALL terminal age grounded to the frame to complete the signal circuit.
Edited by steve(ill) - 14 Dec 2025 at 6:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 3:17am
Yeah Steve,all the 3 wires are kinda small. Push button twists from crank to start. Also the red wire has a fuse which looks good to me
Don't have any like it. I'll buy some and see what happens
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 10:03am
take a volt meter.. or a battery and bulb... and connect between the RED and the WHITE wire , then push the button and see if you have continuity.. If that dont work, check between the red and the black for continuity... I have no idea why it has 3 wires.....  I guess you should have continuity on one when you PUSH the button and maybe on the other when you TWIST the button  ??
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 10:19am
I would think that none go to ground.  red (fused) goes on battery, one on starter solenoid, one on coil +.  Not sure, just my guess, but a meter can tell you quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 12:18pm
Thanks Steve and Dave. I'll see what I can figure out. The controller twists from crank or start and then you press the button. Wish it came with directions. Thanks again
Edited by ACinSC - 15 Dec 2025 at 12:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 1:15pm
Dave is probably right.. When you TWIST it, thats like turning on the KEY.. you get Ignition and Accessories... like power to the COIL.... Pushing the button is the START/ CRANK position.... You just need to figure out which wire is which.. ONE will be connected to RED when you TWIST.. Other will get hot when you push the button..
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 1:56pm
Big question is... is the engine starter switch still good?
Most remote starter buttons were just two wire for cranking the engine only.
there are 3 and 4 wire remotes too but google search doesn't really show those types.  Back in the 70's the Tech collage had the three wire remotes so you could start engines right on the test stand. Hook up a battery, connect the fuel line and clip on the remote and start run and shut off the engine with the remote. If you were going to run the engine longer than a couple minutes, then you needed to hook up a water line too.
 Three wire remote - The red wire clipped on the hot post on solenoid, black goes to IGN small post (two post solenoids) on solenoid or to coil. and the blue wire should be momentary contact that engages the solenoid for start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 2:33pm
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 2:03pm
Update. Red clamp on positive battery post
Black clamp on solenoid post with white wire. Press button and engine turns. Guess the third blue clamp goes to the distributor if you want to start engine? Thanks guys!
