6060,6070,6080 with duals
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 6060,6070,6080 with duals
    Posted: 14 Dec 2025 at 10:06pm
Oddly I’ve never seen any of these with dual rear wheels. Anyone out there ever done it?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 4:15am
Yes, have a set of clamp-ons for the 6080, haven't been on in years though. Dad used them in the spring when planting and fall pulling wagons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 8:51am
Since most of them were not heavy tillage tractors,most never got dualled. I have clamp on duals for my 45 and used to use them when it was the big horse on the farm. My 8070's grin and wink at the 45 when they drive by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 10:12am
I figured someone had done it but just haven’t seen pictures of any. I’m sure it makes for a nice looking tractor along with adding traction on a 2 wheel drive. Our 20’ AC 2200 disk would be 1 implement that it would probably help with traction. Don’t have duals for my XT either. Just was curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 11:28am
Mine had dual hooks on when I bought it, but no duals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 11:38am
The beauty of duals when discing plowed ground, is the disc can be operated a little shallower and still wipe out the tractor tracks. A win-win situation !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 12:56pm
We used to spring plow,harrowgate then disc in dry fert and harrowgate again. The duals were a big help in staying on top and keep traveling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 2:56pm
A D-17 IV gasser would handle a 13' 6" 200 series disc much easier with 16.9 x 28 duals on the rear.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 3:49pm
Not the same but when I got my 185 came with duals, have never been on since I got it, just use it for light work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 6:16am
Cousin that lives a mile away still has the 6060 his dad bought new. Had 1804x28's when new. Uncle Dan had clamp-on duals for it. The son, Doug, got a pair of 18.4x34 tires, wheels, and centers from the junkyard, probably from a 6080, that it now wears. Don't think he has duals for it now though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 8:15am
That will step up road gear for him !!   6060's were pretty slow with 28 inch rubbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 3:05pm
That's the disc I have for the 45. T-bar hitch makes it work great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 3:35pm
We had the snap-coupler style Traction Booster drawbar too. Between that and duals, any and ALL discing (even plowed ground) was HIGH 3rd gear always.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2025 at 2:59pm
When my 6060 came new, Dad used it to pull a corn planter  after about 25 acres he put duals on it off the wd45 I believe they were.  not 18.4 x 28 like the inner tire.  I took the 18.4 off and put on 16.9 x 34 tires and rims  made a much better tractor out of it then, and yes road gear was much  nicer if you had to get anywhere with it.  It is a nice lightweight tractor  great on a baler or forage blower.  I use it just for an auger at harvest now and for spraying.   A full tank of fuel, I can spray 450 acres.  It is the most economical set up I have on the farm.
This page was generated in 0.083 seconds.
