C-CA confusion
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: C-CA confusion
    Posted: 30 Nov 2025 at 12:21pm
check the link,, this some kind of frankenstien?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 12:28pm
if it has spin outs and a 4 speed.... its a CA
does not have a platform.... but one photo of the right rear looks like a CA hyd pump.
Edited by steve(ill) - 30 Nov 2025 at 12:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 12:52pm
I guess it not having the platform is what is throwing me off..and no hand clutch,, yea, I know some don't have the hand clutch.....
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 8:33pm
Definitely a CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 9:23pm
I agree Gary, CA
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:24pm
I am currently in the middle of putting a CA transmission in my B.  I doubt I'm the first.
1951 B
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 55 minutes ago at 6:29am
Hmmm, I have a spare transmission from a CA. Now if I had a B.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 25 minutes ago at 6:59am
Makes for a much more user friendly B,wish I'd of had a 4 speed in the B I used to cultivate corn with back in the day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 37 minutes ago at 9:47am
I'm hoping so.
Also, I need the road gear to get it up to the speed needed to do the Mackinac Bridge Vintage Tractor Crossing which is a goal of mine- using my Dad's B, which was also the kind of tractor (though not THE tractor) that my Grandpa started with when he bought his farm.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 41 minutes ago at 12:43pm
Hough, i thought the 4 speed had a lower low gear and just a little different in high (4th compared to 3rd in the B) ??   Do you know the final drive gear ratios of the B compared to the  CA ??   What road speed are you trying to get ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 45 minutes ago at 2:39pm
I did the math, but it's been a while.  I will look for my figures.
I need to be able to sustain 10 mph.  A stock B, and mine runs great, does just under 8 mph in 3rd.  My math got me to about 14.5 mph at 1,600 rpm using the CA transmission and B finals (yes, the bolt up).
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 25 minutes ago at 3:59pm
Dr once post that the B had a 27-22 gear too reduction and the CA had a 47 -24 tooth reduction in the trans in high gear..   1.227 vs 1.958... so your right, about 50% faster..
Edited by steve(ill) - 4 hours 24 minutes ago at 4:00pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 17 minutes ago at 4:07pm
Now that I own a Model CA (and three C's) I was recently perusing the parts books on the AGCO site and noticed that they listed the tooth counts for the transmission.
Model CA:
1st - 18/50 - 2.778:1
2nd- 26/41 - 1.577:1
3rd - 30/37 - 1.233:1
4th - 49/24 - 0.490:1
CA Differential:
6/37 - 6.167:1
CA Final Drive:
13/77 - 5.923:1
CA Overall Ratios:
1st - 101.5:1
2nd- 57.6:1
3rd - 45:1
4th - 17.9:1
Model B/C
1st - 14/35 - 2.50:1
2nd- 19/26(?) - 1.37:1
3rd - 27/22 - 0.815:1
B/C Differential
7/37 - 5.286:1
B Finals:
14/67 - 4.786:1
B Overall Ratios:
1st - 63.2:1
2nd- 34.7:1
3rd - 20.6:1
CA transmission with B Finals:
4th Overall: 14.5:1
Edited by Les Kerf - 4 hours 7 minutes ago at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 6 minutes ago at 4:18pm
OK... so a standard CA would be about 50% faster than a B...  12 mph vs 8 ???    But if you retained the B finals and bevel gear , with the NEW CA trans , you would get maybe 30% more .. so that would get you up to the 15 MPH range ?  ( just looking at the numbers in my head.. not actual calc)..
so depending on the rated engine speed.... i think Hough is right on his calcs..
Edited by steve(ill) - 4 hours 2 minutes ago at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 39 minutes ago at 6:45pm
... if you retained the B finals and bevel gear , with the NEW CA trans...
I wonder if the B/C Ring & Pinion gears in the differential will fit in a CA box? That would certainly give the fastest combination of 12.4:1 overall ratio Cool
The Model C had three different final drive ratios:
19/94 - 4.947:1 (Prior to Tractor #C-109)
15/82 - 5.467:1 (#C-109 - #C-15714 w/air tires up to #C-23080)
12/69 - 5.750:1 (Tractor #C-57368 + up. Used on #C-15714-#C-23080 w/steel wheels)
Edited by Les Kerf - 1 hour 34 minutes ago at 6:50pm
