D 15 governor |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3123 |
Topic: D 15 governorPosted: 30 Nov 2025 at 4:48am |
Pulling the disc and the engine over revved. Throttle lever also moves on its own. Have tractor in my little shop now. Pulled dist yesterday, gov shaft has a lot of play. Book says remove rad next,then gov. Anything else I need to do while I'm in there? Thanks
Edited by ACinSC - 30 Nov 2025 at 4:49am |
Posted: 30 Nov 2025 at 10:45am |
Inspect for timing gear damage. Fix whatever is broken.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8708 |
Posted: 30 Nov 2025 at 11:27am |
....and I remember MACK saying a nicked or slightly distorted timing gear tooth will cause bad harmonics and lead to another failure....sounds reasonable. Don't cut a corner?
ACinSC
Posted: 30 Nov 2025 at 12:50pm |
Thanks Dr Allis and Steve M
Probably just buy a new governor and be done with it. |
Posted: Yesterday at 12:14am |
Oh but wait....you have to inspect the cam and crank gear for damage also!
ACinSC
Posted: Yesterday at 3:37am |
Haven't got it off yet, but I hope for minimal damage. Only ran engine a few minutes. Thanks
ACinSC
Posted: 16 hours 1 minutes ago at 3:02pm |
Have the gov off. Ears? on the weights have been hitting the inside of the housing. Guess something is missing or broken ? I'll try to get some pics posted. Thanks
Edited by ACinSC - 15 hours 60 minutes ago at 3:03pm |
Joined: 11 Sep 2009 Location: illinois Points: 88948 |
Posted: 14 hours 55 minutes ago at 4:08pm |
ACinSC
Posted: 13 hours 44 minutes ago at 5:19pm |
Thanks Steve!
Posted: 13 hours 39 minutes ago at 5:24pm |
i have not reviewed all the you tube movie... Not saying the guy is 100% right.. but its a good base line for disassembly and repairs..
ACinSC
Posted: 12 hours 51 minutes ago at 6:12pm |
I watched it, learned a couple things. Thanks!
WeisAC2
Posted: 11 hours 51 minutes ago at 7:12pm |
Posted: 9 hours 17 minutes ago at 9:46pm |
For the record, a D-15 does not have a spring connected to the carburetor linkage. None. Just another old wives tale.
ACinSC
Posted: 3 hours 1 minutes ago at 4:02am |
Thanks Dr Allis. Any thoughts on what happened to my governor? My plan is to replace it and also the larger bushing. Not sure how to pull the small one. Thanks again everyone!
Posted: 34 minutes ago at 6:29am |
Probably a bad plan when you have zero tooling to do so. I've OH'd 5 or 6 of those in the last 50 years and never replaced either bushing. The failure ?? 60 or 70 years of no one replacing the weights with new ones I'd imagine. Same old story with the 201/226 being far worse.
