D17 tranny |
D17 owner
Joined: 03 Jul 2010 Location: ladysmith Wi Points: 225 |
Topic: D17 trannyPosted: 08 Jan 2011 at 7:26pm |
Well The D17 Tranny went bang today out feeding cows it made a loud nose sounds like it is by my right foot by the brake pedals. I dose not do it all the time but when it dose it stops the tractor and I sounds like parts are leaving. All I did to it is laoded it on the goseneck and put it in the shed. I have to take the loader off and look at it more. I was thinking like a bearing went out and the balls are playing with the teeth of the gears it did it to me in 3rd and R. I never tore into a transmission before. What do you think it is? Is it hard to work on the tranny? Open to enything, I know I could be alot of things. This was the last straw thow on farming the cows are going the land is going to be rented I am thinking of restoring the 17 and take it to shows and thinking of trading of the 1105 MF and getting a 6080. Any help would be GREAT thanks. Eric
Allen Dilg
Posted: 08 Jan 2011 at 7:32pm |
Hello D17 I would pull the drain plugs just a LITTLE TO SEE IF THERE IS water/ICE in the cases, cheap/easy. Possible
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 08 Jan 2011 at 7:37pm |
What series is it? Might be the brakes if it is the later series....
ALLIS EXPRESS!
This year: |
D17 owner
Posted: 08 Jan 2011 at 7:48pm |
It is a series one I put brakes on it this fall new pads and drums wheel seals also. That was the first thing that can to my mine also. I did back off the right hand brake I was not sticking but backed it off anyway and it still did it. Allen Ya that will be the first thing I do maybe I will even get a tooth or two. Eric
David Maddux
Posted: 08 Jan 2011 at 10:31pm |
It sounds like a ball came out of socket in the brakes. That is if it is a series 3 or 4. Dave.
David Maddux
Sorry, I didn't read good enough on the last post.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 09 Jan 2011 at 6:37am |
Maybe a pinion/main shaft bearing finally gave in. Do not keep using machine.
Posted: 09 Jan 2011 at 7:34am |
I might be thinking intermediate gears under the dashboard. Were you using the PTO when the "big bang" occured??
D17 owner
Posted: 09 Jan 2011 at 9:16am |
DrAllis Yes the pto was on. We turn it on when it is cold to circulate the oil and keep it warm. It was only -10 below when it went bang.
