D 15 governor
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 governor
    Posted: 30 Nov 2025 at 4:48am
Pulling the disc and the engine over revved. Throttle lever also moves on its own. Have tractor in my little shop now. Pulled dist yesterday, gov shaft has a lot of play. Book says remove rad next,then gov. Anything else I need to do while I'm in there? Thanks
Edited by ACinSC - 30 Nov 2025 at 4:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 10:45am
Inspect for timing gear damage. Fix whatever is broken.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 11:27am
....and I remember MACK saying a nicked or slightly distorted timing gear tooth will cause bad harmonics and lead to another failure....sounds reasonable. Don't cut a corner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 12:50pm
Thanks Dr Allis and Steve M
Probably just buy a new governor and be done with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 12:14am
Oh but wait....you have to inspect the cam and crank gear for damage also!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 3:37am
Haven't got it off yet, but I hope for minimal damage. Only ran engine a few minutes. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 3:02pm
Have the gov off. Ears? on the weights have been hitting the inside of the housing. Guess something is missing or broken ? I'll try to get some pics posted. Thanks
Edited by ACinSC - 01 Dec 2025 at 3:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 4:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 5:19pm
Thanks Steve!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 5:24pm
i have not reviewed all the you tube movie... Not saying the guy is 100% right.. but its a good base line for disassembly and repairs..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 6:12pm
I watched it, learned a couple things. Thanks!
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 7:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 9:46pm
For the record, a D-15 does not have a spring connected to the carburetor linkage. None. Just another old wives tale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 4:02am
Thanks Dr Allis. Any thoughts on what happened to my governor? My plan is to replace it and also the larger bushing. Not sure how to pull the small one. Thanks again everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 6:29am
Probably a bad plan when you have zero tooling to do so. I've OH'd 5 or 6 of those in the last 50 years and never replaced either bushing.  The failure ?? 60 or 70 years of no one replacing the weights with new ones I'd imagine. Same old story with the 201/226 being far worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 8:19am
Thanks again Dr Allis.There's a lot of play at that larger bushing and it looks easy enough to replace.A new governor should outlast me easy enough.
Edited by ACinSC - 02 Dec 2025 at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 10:53am
Now I see the weights have a inside ear? that keeps it from hitting the inside of the housing. One of mine is missing. Wonder where it is? Bottom of the oil pan would be good . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 4:03pm
Have center in window with #1 on the compression stroke. If I bar the engine over so the crank gear turns 2 full revolutions will it be in the same place? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 4:36pm
YES... every 2 revolutions you get on the COMPRESSION stroke... and you should see TDC #1.
Edited by steve(ill) - 05 Dec 2025 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 4:40pm
Thanks Steve!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2025 at 4:22am
Turned engine, have it back up on #1 with center in the window. Crank gear looks good
No sign of the governor weight piece. May drain the oil and see if it's in the pan. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2025 at 1:45pm
If it's not visible in or around gear train i wouldn't worry about it. It can do no harm in the pan. Likely hood that it ever makes it to drain hole is slim too. It's not magnetic so fishing for it not happening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2025 at 3:03am
Thanks Steve M . Governor should be here in a few days and I'll put everything back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 10:24am
New governor is here. My book says the thrust bearing face goes to the front (radiator) . Is that the bearing end? Old one fell off before I could mark it . New governor has the bearing end to the back. Thanks
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 2:00pm
Brg end to the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 2:56pm
Thanks Alvin! Makes sense that the bearing end goes to the forks in the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 7:35am
I'm about done with this job and have another question. Book says at 1750 rpm F 25 should be in the window. Last time I had engine WOT with F 25 up. Which is correct? Think rpm is about 2200 wide open .Thanks
Edited by ACinSC - 11 Dec 2025 at 7:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 8:07am
The distributer advance is fully advanced at 1750 RPM if everything in the 60 year old distributer is working correctly. If you do the wide-open-throttle setting it is no different than 1750 and no mistakes are made. You might think you are at 1750, but maybe your tachometer isn't quite accurate. Full throttle is the only way to do it on ANY A-C gas engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 8:14am
Thanks Dr Allis!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 2:32pm
Have my old D 15 running again
Have 2 old dwell meters. One reads 30 and one 32 . Set the timing by ear. When I get some help I'll check it with my light.WOT is a little shy of 2200 .Thanks for the help guys!
Edited by ACinSC - 12 Dec 2025 at 3:39am
