D 15 governor |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3118 |
Topic: D 15 governorPosted: 20 hours 7 minutes ago at 4:48am |
Pulling the disc and the engine over revved. Throttle lever also moves on its own. Have tractor in my little shop now. Pulled dist yesterday, gov shaft has a lot of play. Book says remove rad next,then gov. Anything else I need to do while I'm in there? Thanks
Edited by ACinSC - 20 hours 6 minutes ago at 4:49am |
Posted: 14 hours 10 minutes ago at 10:45am |
Inspect for timing gear damage. Fix whatever is broken.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8708 |
Posted: 13 hours 28 minutes ago at 11:27am |
....and I remember MACK saying a nicked or slightly distorted timing gear tooth will cause bad harmonics and lead to another failure....sounds reasonable. Don't cut a corner?
ACinSC
Posted: 12 hours 5 minutes ago at 12:50pm |
Thanks Dr Allis and Steve M
Probably just buy a new governor and be done with it. |
Posted: 41 minutes ago at 12:14am |
Oh but wait....you have to inspect the cam and crank gear for damage also!
