Valve lapping
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Valve lapping
    Posted: 3 hours 41 minutes ago at 8:25pm
I’m sure this has been long discussed if lapping is needed. I just had hardened seats installed and valves ground. Personally I trust modern machining for a good seal. How many of you still lapped valves with hardened seats?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 42 minutes ago at 9:24pm
always a good idea to get a finish lap.. if nothing else, to CONFIRM it is correct..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 44 minutes ago at 10:22pm
Can't hurt? When seats and valves are ground/cut correctly it's not needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 minutes ago at 11:35pm
HELL  NO !!     Ask yourself this: do you think GM or FORD for example take the time to "lap" valves and seats after their modern and expensive valve grinding equipment has just mass produced hundreds of cylinder heads a day ?????? NOPE.
This page was generated in 0.058 seconds.
