Hd6g hydraulic tank plate
Trevor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trevor Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g hydraulic tank plate
    Posted: 16 Nov 2025 at 11:05am
Hey I'm in need of the plate that bolts to the top of the hydraulic tank. The part number is 73016100. It's sandwiched between the control valves and tank. It is number 5 in the image
Edited by Trevor - 16 Nov 2025 at 11:06am
random_farmhick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote random_farmhick Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 42 minutes ago at 9:43pm
What’s wrong with your plate? I’ve never seen that style, only messed with dozers. If it’s warped, could you just have it surfaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trevor Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 16 minutes ago at 5:09am
No it appears that at some point in it's years, something fell on the tank, dented the tank, cracked that plate in half. Someone rigged it and it leaks fluid like that's it's job.
This page was generated in 0.041 seconds.
