Drilling holes in concrete |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3087 |
Topic: Drilling holes in concretePosted: 1 hour 59 minutes ago at 2:43pm |
Drilled 4 today. Brand new concrete bit. Went well for about an inch. Then it was tough. Does a hammer drill make much difference? I have more to do, Thanks
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42061 |
Posted: 1 hour 46 minutes ago at 2:56pm |
Big Difference with a hammer drill -bigger the unit the better and faster the drill works .
Trawler II
Joined: 04 Jul 2017 Location: Missouri Points: 3544 |
Posted: 1 hour 15 minutes ago at 3:27pm |
A rotary hammer drill and SDS bit will be a night and day difference. If you have a lot of holes to drill renting a rotary hammer drill and purchasing a bit is the way to go. SDS bits are a bit expensive compared to standard carbide, with a lot of holes to drill they are a bargain.
Edited by Trawler II - 1 hour 14 minutes ago at 3:28pm |
"Most people find it easier to believe a simple lie, than the complex truth"
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34542 |
Posted: 3 minutes ago at 4:39pm |
If has Creek rock in the mix is like drilling granite.
