Wd45 diesel generator repair
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 diesel generator repair
    Posted: 14 Nov 2025 at 6:07pm
Good evening!!
Is there a source for the original 12volt generator parts?
I notice the brushes are very well worn and it’s not charging very good.
I’d prefer to leave it original with the power steering pump on the back of it if it’s possible.
Thanks
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 5:09am
Most likely it is a Delco Generator and same as from a '50's to early '60's Chevy generator. Take yours apart to confirm, click on below, scroll down, and take your pick:
Edited by Phil48ACWC - 15 Nov 2025 at 1:25pm
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 6:49am
AGCO Has Them Part # 70231998
Edited by Alvin M - 15 Nov 2025 at 6:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 7:49am
A local starter/alternator repair shop can make it as good as new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 11:52pm
When I’m done using the tractor I will slip it apart and confirm what it needs, only want to pull it apart once.
What involved in resealing the power steering pump on the back of the generator? It seeps enough to make a mess of the generator parts.
Got an itch to get the leaks sealed and the charging/wiring working properly.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:48am
PS pump probably needs a seal replacement. Get the numbers off the seal and measure the seal when you take it apart and get a new one from Ebay or any seal supplier on line, unless you want to pay nutso pricing from Agco. Also keep in mind, the '57 Chevy came with a generator with the PS pump attached. So that will narrow your search for parts.
Edited by Phil48ACWC - 18 Nov 2025 at 6:17am
This page was generated in 0.107 seconds.
