D-17 Series III Governor
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series III Governor
    Posted: 1 hour 8 minutes ago at 12:39pm
I have a Series III D-17 that the governor will run away on when it is at is sitting at idle...when you move the throttle lever back to the idle position the RPM's will go back to idle.  From what I can remember this problem started back in the early 1990's when my Dad got a bigger manure spreader, which was probably too big of load for the tractor, hit a bump in the field with a full load and broke the drawbar and this governor issue accorded at the same time.  He had it to our local dealer which still had A-C mechanics at the time, they had it apart and couldn't find anything wrong with it and he took it to a local A-C after hours mechanic and he couldn't find anything wrong with it either.  Dad passed away a few years ago and left the tractor to me and I thinking of tearing into but have no idea what to look for...any suggestions...thanks in advance.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 12:53pm
If the tractor got parked after this all started, normally one would think exploded governor weights is the issue. If the tractor continued to be used with a "just doesn't stay idled" problem, that would mean the friction discs on the hand throttle (under the fuel tank) need to be tightened up to keep the throttle in one spot and not change by itself.  Broken governor weights will allow the engine to rev waay high with little hand throttle movement from the dead idle position.  If they job was handed to me, I'd yank out the governor and check the weights first to know are these good or not good ??
