Painting a trailer |
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 153 |
Topic: Painting a trailerPosted: 22 hours 11 minutes ago at 10:24am |
I have an old trailer that needs a fresh coat of paint. It has numerous rust areas. Rust areas are not very heavy just enough to know the paint is gone. The trailer is yellow and I would like to repaint it black. Should I prime just rust areas or apply primer to the entire trailer? I will wire brush the rust areas. Other than pressure washing what should I do to the areas that still have paint?
Thanks Avery |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34450 |
Posted: 21 hours 32 minutes ago at 11:03am |
Will have to clear any loose paint, and scuff the surface of the rest or will not stick for long..
Joined: 11 Sep 2009 Location: illinois Points: 88634 |
Posted: 19 hours 41 minutes ago at 12:54pm |
use a palm sander with 120 grit paper to scuff everything up.(after wire brushing the rusts)... I like the Rustoleum Red Oxide Primer for rusted spots... Also a good primer for the old paint areas.. You dont have to put a thick coat on, just enough to cover and let it BOND to the old paint.. Let it dry for 24 hours, then any type of enamel paint for a top coat.
Edited by steve(ill) - 19 hours 41 minutes ago at 12:54pm |
AveryD12
Posted: 10 hours 54 minutes ago at 9:41pm |
Thanks. Had not thought about a palm sander but had considered an angle grinder with a wire wheel on the painted area. A palm sander would probably be safer as that wire wheel will kick back sometimes. Just wasn’t sure if sanding/brushing was necessary. I like the rust-o-leum red oxide primer for rusty metal just wasn’t sure if it would be good to use on the areas that still had paint or if I needed to use something else. Thanks again for the help.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1127 |
Posted: 9 hours 60 minutes ago at 10:35pm |
They have angle grinder sanding discs.
They leave a very nice bare finish, very handy cleaning up stick weld splatter and rust pits. |
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5060 |
Posted: 2 hours 25 minutes ago at 6:10am |
I first use a needle scaler to remove anything loose, then sand it. I blow it off with compressed air and wipe it down with Preps-all. Then I use Rust Reformer | Rust-Oleum over any spots with visible rust. Let the Rust Reformer (or Rust-Converter) dry, prime with a primer that is compatible with the paint I am going to use. Lightly sand again, blow it off, another wipe down with Preps-all and paint. I lightly sand, blow and wipe between paint coats.
AveryD12
Posted: 1 hour 38 minutes ago at 6:57am |
Thanks everyone for the great tips!
