940 wheel loader
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: 940 wheel loader
    Posted: 19 Oct 2025 at 12:34pm
Does anyone know where i can get a operator or service manual for a 940 wheel loader. Everything works but the brakes. I know im going to need a master cylinder or akit for it but ive never seen one like that. Any insight would be appreciated
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2025 at 5:07pm
I need to fix mine too but when I looked at the master I thought it looked like an ih truck cyl.  Hopefully get to that this winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2025 at 6:24pm
Ill take it out and see what i can get matched up. Im hoping someone has prior experience and will chime in
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2025 at 9:48pm
There should be a casting number. That should cross with any competent parts place
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 4:08am
Most were single line as IH Ford and GM back in the day. Older parts guys should have a clue on these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 4 minutes ago at 4:54pm
Masters for my 545B are a 60's Ford ton? You're looking for bore size mostly in you search.
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 12 minutes ago at 4:46am
Don't know whether you managed to get a manual, but I see there's one on Ebay at the moment - https://www.ebay.co.uk/itm/353891100291
Seems to be missing a front cover, worth checking whether it's complete otherwise.
There are also scans of a few pages on the Jensales website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 16 minutes ago at 8:42am
Thank you. I dont have a manual yet. I called Jensales but no answer. Ill probably call Jensales again
1984 80780
1957 D14
616 tractor
