D 15 engine oil |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3232 |
Topic: D 15 engine oilPosted: 28 Oct 2025 at 5:33pm |
Another dumb question, maybe. When I check the oil with a cold engine it's a touch low. After engine warms up oil level is on the line. Seems it should be the other way around to me. Thanks for any insight
Joined: 11 Sep 2009 Location: illinois Points: 89931 |
Posted: 28 Oct 2025 at 5:42pm |
Google...
Yes, oil expands when it gets hot, a phenomenon known as thermal expansion. This is why it's important to check engine oil levels after the engine has been running for a few minutes and then has been allowed to sit for a few minutes to drain back into the oil pan, as checking it when cold can lead to overfilling if it's topped off to the "full" mark
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8864 |
Posted: 28 Oct 2025 at 8:45pm |
Steve,is what you say in the manual? Never heard of warming a little then setting to check oil. Can't imagine full cold could grow enough hot to matter.
Posted: 28 Oct 2025 at 9:30pm |
i dont know about manual.. this is just a GENERIC comments about oil expansion due to heat... It can happen... E J just wanted an explaination of WHY the level changed with temp... I normally check oil level cold and call it good..
Edited by steve(ill) - 28 Oct 2025 at 9:32pm |
ACinSC
Posted: 29 Oct 2025 at 4:49am |
Thanks Steve I didn't think about oil expansion. Makes sense. Guess if I add a little oil to get the level on the full line it wouldn't hurt anything?
Edited by ACinSC - 29 Oct 2025 at 4:52am |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 703 |
Posted: 29 Oct 2025 at 11:08am |
Im no engine scientist but ive ran this stuff since i was a boy. Id keep it on the full mark when cold and go about my business. Id rather have it a little too full than too low. I read somewhere that when the 8000s came out they were loosing engines on steep hills in wheat country. AC engineers solution was to run them a gallon over full. Dont know if it is true but seems reasonable
1984 80780
Posted: 29 Oct 2025 at 2:48pm |
It was after fwa arrived on the 8000's. They could climb too steep or go down hill too steep and ran out of oil. A gallon over still isn't near the crank.
