Char-Lynn WD45 Brackets
Lingle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Topic: Char-Lynn WD45 Brackets
    Posted: 06 Oct 2025 at 12:28pm
Good day everyone!  I recently purchased a removed from the tractor "complete" Char-Lynn power steering system for my WD45.  unfortunately it is missing 2 brackets and I am hoping someone could provide me some rough measurements so I can make them.  Given they are flat bent parts, should be easy to make.
the brackets I need to make are the inboard bracket for the torque generator and the pump bracket to front cover on the "passenger side".  I need items 300 and 556 in the attached photo.  its likely easier for me to make them if someone could help me with what they are measurement wise.
Thanks!
Edited by Lingle - 06 Oct 2025 at 12:30pm
35 and 41 WM crawlers, 49 WD, 53 WD45 wide front, 49 JD A, 52 JD B
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 9:41pm
I think I have them. No guarantees, but I think I have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 2:22pm
sent you a private message
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2025 at 10:05am
“Bump”
This page was generated in 0.297 seconds.
