Ford Edge power windows?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Ford Edge power windows?
    Posted: 15 Sep 2025 at 11:01am
My BIL has a Ford edge  mid teens with power windows. None of the windows work, all of them stopped working  at same time. Checked the harness, power to the switch. Switch checks OK. No movement on any window. It has a child lock out on windows. Could this have an interlock causing problem. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2025 at 12:28pm
the Drivers Door is the control panel.. You can run any of the 4 windows from there.. EAch door has ONE switch for that door only.. I think the "child switch" just lock out the back two windows.... If EVERYTHING craps out at the same time, its normally the drivers door panel or the power to it... Have seen the harness  get pulled at the door panel and break a wire to two running into the door..... If its not a fuse, etc, i would look at the drivers door control panel, and the wire harness feeding it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2025 at 12:37pm
not your exact car, but this guy does a good job of explaining..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2025 at 7:29pm
Got it fixed. Was a relay that was causing problem. Thanks, Tracy
