Battery cables?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Battery cables?
    Posted: 09 Sep 2025 at 11:08pm
Who has the best battery cables? What is best ends to buy if you make your own? What is best end fastening system? Thanks, Tracy
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 5:01am
I had one made up at the local farmers union service station a couple weeks ago that I was very impressed with. I can't give you a name brand or anything because I don't know it. But we used really heavy cable (I believe it's called two-ought?????) Cut it to correct length,stripped the ends appropriately, and crimped the ends on using the hydraulic hose crimping machine. Then put heat shrink tubing in place on the connections. Turned out great. Would think that some auto parts places would be set up to do that. Darrel
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 5:53am
Tracy, I have used
Many times, they are quick and have always had good prices.
I finally got mad during the Covid nonsense and bought a hydraulic crimper and got a selection of ends that I most use, and a roll of cable. Problem solved!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 6:12am
If you go the 'make your on route' be sure to properly 'tin' the ends to consolodate the strands into a solid conductor and seal the ends with 'liquid rubber' or similar product.
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 6:56am
Quickcable. Sold through many dealers. CNH dealers can have parts direct shipped to them (slow, not from warehouse, likely minimum order), , basically the QC P/N with a ZQC on the front of it. QuickCable is often cheaper in the end, but again, minimum order likely applies.
Edited by joe - 10 Sep 2025 at 6:58am
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 9:49am
I have ordered through Waytek to get both ends and cable, not worth doing unless you are doing a larger order. To crimp the ends we use the hose crimping tool, makes a nice tight crimp. If you make your own make sure to use something to seal it, heat shrink with adhesive lining is best.
I realize not everybody has a hose crimper, but if you are on good terms with your local hydraulic shop you could probably convince them to do it. It has been a while since we have done any, but I think we use 00 cable.
Ted
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 11:33am
Take off old cables to have pattern.. Go to local parts store and ask if they can make battery cables, if yes, then I'd ask for #1 gauge for gas and #2 OO (2 ought)  for diesel, get heat shrink tubing on both ends.
 You'll never be short on wiring from battery to starter with those cable sizes. Unless you're over 500 hp and it's setting where it's really cold.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 12:01pm
I never thought of using a hose crimper for battery cables; we always had them at the sawmills when I worked there but now I am retired so that is no longer an option for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 1:25pm
I just use my crimper for Hi-Tensile fence connections. and get cable and ends from the local HD truck parts place. And ALWAYS use heat shrink at the ends.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 2:10pm
I bought premade 18in with hole-tabs, suitable for 6v even though I converted to 12v, through Amazon. Then got a set of bronze battery terminal ends the cables could bolt to. Had to drill the starter/solenoid ends slightly larger.
That was the least cost to headache option.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 7:58pm
I use ones from NAPA, the ones that use the pellet in them, then use shrink tube over the connection.  Just have to keep the cable end orientation in mind for the second end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 8:43pm
Thanks guys! I will look at some of the places you mentioned! Thanks again! Tracy
