Adjustable rims
Huolti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Topic: Adjustable rims
    Posted: 25 Aug 2025 at 1:39pm
I have a restored AC WD with adjustable rims. I cannot keep them tight on wedges and the kept sliding in. Are the wedges in the rim clamps worn enough to not tighten enough. Looked for new ones but can’t find any.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 1:51pm
You are missing a piece at each eccentric location. The eccentric doesn't contact the wheels rail. There is a piece that goes between them. It is called a "block" in AGCO Parts books.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 3:16pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 6:04pm
Where are you in Alberta?  I have several complete sets of those clamps with the blocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 6:42am
Also needed are the stop blocks the go on the drilled rail with a bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 10:37pm
Hi.
I’ve bought other stuff from you I think. I’m by New Norway. After harvest I’ll give you a call. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 10:39pm
Previous message was for Alberta Phil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 9:25am
Got it!
This page was generated in 0.174 seconds.
