Tire balance beads
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Tire balance beads
    Posted: 12 Aug 2025 at 8:14pm
Just bought 4 new tires for my dually ton truck. I dismounted / mounted all 6 tires myself. Front tires had good thread so removed them from front aluminum rims & mounted them on outer rear aluminum rims. So 2 new steers & 2 new rear inside on steel rims.
Used 4 ounces of glass balance beads inside each tire after removing old lead weights from rims.
Just did a 2000 mile round trip with it towing 32’ gooseneck. Heck of a SMOOTH ride.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 5:21am
I know several who use them in motorcycle tires.
I use ride on. It’s a thick liquid .
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 6:38am
I've got balance beads in two pickups, happy with them.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 7:14am
I have been using them for a couple years now. Really happy with them, and they got rid of a shifter vibration in my brother's pickup, probably caused by an out of balance brake drum rather than tire.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7045, 190XTD series??? project(or maybe parts)
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 8:35am
Hows that going to work matching used and new tires? I left my worn down spare on for a while with a new tire aside of it and it seemed like it ground the last little bit of tread off it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 8:48am
Fine. Been doing it that way for 25 yrs. The fronts are mostly just cupped on outer edges. Their inside threads are even & probably still 3/4 thread heights. Ford Ton truck is 2wd, so fronts always cup edges first. Mostly interstate/highway driving too. Not much gravel, crowned rock chip, or blacktop roads.
Edited by AC7060IL - 13 Aug 2025 at 8:49am
This page was generated in 0.386 seconds.
