1948 Allis Chalmers grader
Brinkley70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinkley70 Quote  Post ReplyReply Direct Link To This Post Topic: 1948 Allis Chalmers grader
    Posted: 11 Aug 2025 at 9:00pm
Hi all,  I had an arm break on my grader.  I'm wondering if anyone has a parts machine?  It's the arm that attaches to the gear box that lowers one side of blade.  I caught a big rock just under the surface and it broke in half at both keyway's.  Here's a picture of part.
It looks to be all cast so I don't think a weld/strap would stand a chance.
Thanks for any help.
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 9:04pm
Cast iron would be brittle and break... It MIGHT be cast steel... and could be welded, if you dont find a replacement..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinkley70 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 9:05pm
Here's a pic of actual part that broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinkley70 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 9:06pm
Yeah that's what I thinking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 10:06pm
Sandblast - Wire brush till clean and wash with soap/ water.. or gasoline...i would bevel the crack on the OUTSIDE so it goes to a thin lip or edge on the ID... clamp it around a brass or aluminum tube so it is ROUND and right size.. or you can finish grind the inside with a die grinder later if you dont have a tube.... Preheat it with a propane or gas torch IN THE WELD AREA  up to 200 degrees or better.. The preheat is good and it will drive off any oil or residue... I always use 7018 stick rod on DC when i weld cast steel... Your milage may vary.
Edited by steve(ill) - 11 Aug 2025 at 10:13pm
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 6:34am
Call Wellers tractor salvage in Kansas 800 255 9325
Edited by im4racin - 12 Aug 2025 at 6:34am
This page was generated in 0.135 seconds.
