D-17 Pie Weights
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Pie Weights
    Posted: 04 Aug 2025 at 8:21pm
I have a complete set of eight pie weights for the early D-17. They have bolts with them. $600 for the whole set.
I also have a set of C side weights ($250) and a set of C rear wheel weights ($100)
I can bring them to the NY GOTO, but I need to know tomorrow (Tuesday).
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:18am
Pmed
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 4:55am
Hi Curt. Those weights are for the series III and IV D-17's, not the series I or II. Yours have the dimple on them. The earlier ones do not. HTH.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 5:12am
Thanks Don!
If that's the case, will they also fit a 170, 175, 180 or 185? Not sure about a 160?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 6:49am
Still interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 4:45am
Pie weights sold
Edited by WF owner - 06 Aug 2025 at 4:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 4:56am
To answer your question Curt, yes they will fit a 170, 175, or 180. they will only fit the 185 if it has 28" rims. Will not fit the 30" rims. Will not fit ac 160, different wheel style.  Don Jr.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 3:08pm
I was told the pie weights with the knub fit the 30" centers as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 4:33am
Due to the fact that each weight only has one bolt you can bolt them to the 30" centers, however, because the center is bigger in diameter they don't sit quite right on the wheel center and you have a bigger gap between the weights and a bigger gap from the edge of the weight to the rim. The 30" wheels have five rails where the 28" had four. Rowe Foundry made a five star weight just for the 30" wheels but they are not as common to find. HTH.  Don Jr.
