D17 Diesel oil pump
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: D17 Diesel oil pump
    Posted: 24 Jul 2025 at 8:11pm
Was working on the D17 project tonight and ran into a snag.  Bolting the oil pump up and must have gotten one side ahead of the other and the flange with the bolt hole has a hair line crack.  What to do now? Jb weld it and run it or find a different pump?  And maybe that crack was there before and did not know it.  I'm ashamed to admit this tractor has been apart longer than we had hoped when we tore it down and just getting back to working on it.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 9:42pm
If another not handy i would V it and braze it. Remove anything heat sensitive first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 6:33am
I broke one of those 40 years ago. Kind of a poor design because the least bit of over torque on the bolts and the ear just snaps off OR cracks the ear for the next poor guy that works on it years later. Go easy on the bolt tightening and loctite the threads so the bolts cannot loosen up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:23am
Would you put any jb weld type epoxy on it just to help or leave it be? Ya when my brother slid that pump up he’s like it doesn’t go all the way. Then I read in the manual it doesn’t. Weird design for sure.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:40am
If I was going to try and save it, brazing would be the best I think.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:29am
Even says in the service manual "flange will not seat tight against the block". It was an issue on these old Buda engines. To answer your question, Id braze it as well
1968 D15D,1962 D19D
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 8:38pm
Cast so NICE to braze !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 8:39pm
Ya read that as well.
ryan
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 7:52am
That almost looks like it's had something applied over the crack previously so maybe you're not at fault anyhow. Tend to agree with the others if you save this pump then vee it out and braze is the way to go.
FWIW I'd rather save this one as any replacement is equally likely damaged in a similar way.
Stuck Farmer
This page was generated in 0.215 seconds.
