Electric A/C compressor
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Topic: Electric A/C compressor
    Posted: 15 Jul 2025 at 10:56pm
John Deere 4050, [6359t (French) engine], a/c compressor is located on top of the engine between exhaust and the radiator.  No way to relocate it to another area.  Believe me.....if it was possible it would have been moved years ago.
The compressors only last 2 or three years.  Spoke with others with the same problem.
Alternatives are converting from a Denso to a Sanden compressor. This requires a mounting bracket adapter kit.
Another idea it to convert to an electric a/c compressor.  Hybrid cars and cars with stop/run engines have electric compressors.
Curious to know if anyone has put an electric a/c compressor on a tractor.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:13am
You'd probably need a 100+ amp alternator for that mode. Besides, to go from
-mechanical belt to ac compressor is more efficient
than
-mechanical belt to alternator to electricity to ac compressor.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:40am
Originally posted by Clay Clay wrote:
Another idea it to convert to an electric a/c compressor.  Hybrid cars and cars with stop/run engines have electric compressors...
What voltage do the use on those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:58am
Most of the "KITS" are 24v and pull something like 90- 100 amps...... 24 x 100 is 2400 WATTS or about 3 HP....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:57am
Sounds like a 200 amp 24 Volt alternator should suffice
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:57am
If you run that high of capacity alternator at capacity, best force feed it air somehow or it most likely won't last long. A ducted fan forcing air at/through the alternator would probable work, but you'll have to deal with space constraints and packaging.
That's All Folks!
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:35am
Thats a lot of continuous current. Good opportunity for a fire. Absolutely do it how you want but id put a belt driven compressor on it and call my next case
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:15pm
I just put in an order for a Sanden A/C Compressor Conversion Kit (AMX10167), $540,  from Abilene Machine.
Planning to flush the system.  Install compressor , receiver/ dryer $28, expansion valve $20 and synthetic Ester Oil $14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:23pm
I'm not sure of why so many failures?? Is it possible that you need to fabricate a simple tin heat shield to reduce exhaust system heat onto the A/C compressor ?? That surely wouldn't be too difficult or costly. This heat shield could also maybe help direct radiator fan blast air towards  the A/C compressor to help cool it off some. I dunno. I'm not there looking at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:10pm
Sounds like a plan Clay... and a couple baffles like Dr said and your good to go !
Product Details
Toss that ancient FrigidaireĀ® A6 air conditioning compressor in the scrap heap and bolt on a SandenĀ® unit with this great upgrade kit!
This is a complete kit to retrofit a modern SandenĀ® compressor in place of the massive A6 unit installed from the factory. We recommend replacing the receiver drier, expansion valve or orifice tube, and cleaning or replacing the condenser for maximum performance and longevity.
The advantages of the Sanden type compressors are many, but include:
No vibration
Better cooling performance
Longer service life
Robs less engine power
As a family-owned company, Abilene Machine has been providing farmers with dependable agricultural replacement parts for over 40 years. Whether you need to make a repair or perform scheduled maintenance, you can depend on us to help keep your equipment in great working condition. And if you have any questions, please do not hesitate to contact our knowledgeable sales staff. We have over 100 years of combined ag parts sales experience to assist you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:31pm
whatever you do, adding a heat shield is a GREAT  mustdo !!
not just a single slab of tin, but 2 separated by a 1/2" air gap, 3 if you've got room.
adding a duct or dedicated cooling fan will also be a BIG help !!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:30pm
There are a few heat deflectors in place.  This configuration was NOT one of John Deere's better ideas.
  I know several people who have the same problem with the same model.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:32pm
Thanks Dr. Allis.  As usual, you have the right idea.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:38pm
A duct is a great idea.  Ducts work great on aircraft engines to direct cool air onto various  engine accessories.  I think I know where I can lay my hands on some SCAT tubing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:08pm
I have no idea what vintage/age this particular tractor is. Does it happen to have what I call an R-4 type Delco A/C compressor like from the mid/late 1980's ?? cause they were junk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:35pm
i would modify the side panel or cut and louver the hood if needed to get a fresh air duct from outside to the back or top of the compressor... Let the radiator fan pull the cooler air thru instead of over the hot engine.... assuming you have a pusher fan.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 49 minutes ago at 7:15am
The fan pull the air through the radiator.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 46 minutes ago at 7:18am
[Nippondenso] Denso - 6E171 .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 14 minutes ago at 8:50pm
OK. I see a picture of it and that is not like an R-4 compressor which GM used.
