190XT traction booster
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT traction booster
    Posted: 08 Jul 2025 at 7:21pm
Need a little help, a picture of the linkages is what I am hoping for. My XT was missing the linkages when I bought it so I purchased the missing items and painted them along with my tractor 10 years ago. I finally got around to installing them this week and ran into an issue when I try to install the position control rod going to the lift arm. When I try to install it in the lift arm, it seams that maybe I have something wrong at the feed back lever/bell crank. Maybe in the wrong hole or I have it orientated wrong. Also, the position control rod and the control rod are different lengths so I have no idea which is which? Hoping someone will take some measurements of those 2 rods and a picture of the bell crank-feed back lever connections for me. My factory manual doesn’t give me those measurements. Thanks in advance
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:21pm
In the top picture, the flat piece that the two rods are attached to, needs to be flipped forward instead of backwards. I don't know if the rods are in the correct holes or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:30pm
Once you flip that piece of linkage over, I was always taught to install a 3/8" bolt and nut in the unused top hole to stop it from ever flipping over again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 3:19pm
Thanks, do the rods go in the same holes after I flip it over?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 6:42pm
I think your owners manual has a picture of that and what the extra holes are for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 8:19pm
Found this sketch near the end of my service manual. Does this look correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 9:33pm
That's it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 10:55am
Thank you sir.
