3 Pt Adjustment Question
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: 3 Pt Adjustment Question
    Posted: 04 Jul 2025 at 8:35pm
I modded my CA custom 3pt hitch so that the lift arms will now go all the way to the ground.  However, I'm concerned that if I let the front of a mower drop too low (say crossing a ditch), that it will bind the PTO shaft.  Is there a general rule about how much you SHOULD allow the PTO shaft to bend?  Avoid crossing ditches or just limit the downward travel?  Best practices?
Edited by dfwallis - 04 Jul 2025 at 9:01pm
1952 CA13092
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 8:51pm
Max deflection for a U joint is 35 degrees, for safety, 20 degrees.  That's what the book says...  In practice, making sure you have the length right, and the joints properly phased are the important things...
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 6:11am
If you drop it slowly when it's running, it will tell you when it is approaching too sharp (chattering). You should then be able to adjust your depth so you can't drop it too low.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 8:04am
Adjustable chains to control the max drop on the draft arms would be a good accessory to have to prevent a disaster like that from happening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 9:33am
There are screw/turnbuckle adjustments.  Just trying to determine where to set them.
Edited by dfwallis - 05 Jul 2025 at 2:36pm
1952 CA13092
